Home > Technical > Upper tailgate release |
Another Global Warmer Member Since: 07 Oct 2010 Location: Sunny Surrey Posts: 17 |
What no tips etc
Tue Oct 12 2010 4:22pm |
m14rsh Member Since: 26 Sep 2010 Location: Norwich Posts: 98 |
Sorry for delay in responding.
Tue Oct 12 2010 4:51pm |
It appears the previous owner had the same issue with one of the lights to the side of the switch as it was taped into place as he had snapped one of the clips/pegs, with the external decorative panel removed (see the photos on my other post) you can get easy access to the back of the switch and lights and can just pin/screw into place. |
Tue Oct 12 2010 4:58pm |
Well here we go again.........
Wed Oct 13 2010 5:14pm |
Rislar Member Since: 04 Oct 2010 Location: Western Lake District Posts: 194 |
I've just replaced mine after reading this! Mine was shot but no water in it just a perished switch!! Thanks chaps another job sorted! PS I changed the battery also as it was well shot after the power drain!! If it aint broke leave it!
Sat Oct 16 2010 2:32pm |
baxc Member Since: 28 Dec 2008 Location: Lancashire Posts: 273 |
hi it will be your micro switch thats causing the flat battery as the corrosion will have got into the switch itself for the sake of £30 its better to buy a new one than clean the original one up |
Sat Oct 16 2010 7:41pm |
rrsjo Member Since: 28 Nov 2006 Location: North Cambs Posts: 551 |
Probably due to a faulty battery - a cell intermittently shorting out. I've just had the same problem. OK one minute, flat battery the next. When I put a charger on mine it came back up from 10 volts to 14.4 volts in 5 minutes and was perfectly OK again - until next time. Gone - 2008 TDV8, Stornoway Grey, ebony, zabrano trim, TV, Tasmods, mudflaps. |
Sun Oct 17 2010 12:45pm |
Well the new switch bought from fleabay arrived this morning and as M14rsh has already said it has a sticky substance bedding the rubber to the switch housing to prevent water from getting in.
Mon Oct 18 2010 9:26am |
quantz Member Since: 05 Mar 2010 Location: Paris, France Posts: 476 |
Interesting. So far I have not this problem, but I'll have it in mind. 2010 TDV6 3.0 HSE Santorini Black Tan Full Leather |
Sat Mar 12 2011 7:04pm |
hario69 Member Since: 06 Jan 2009 Location: Teesside Posts: 68 |
Any advice how to remove the switch?
Mon Apr 25 2011 2:18pm |
V8KIP Member Since: 09 Dec 2010 Location: Kent Posts: 18 |
Following this thread I have just resolved my battery drain problem.
I removed mine (with the tailgate shut as I couldn't open it), by pulling the rubber surround off completely then gently pushing a thin screwdriver head into the left hand side which pushed in the tab (similar to the side repeater tabs) whilst pushing the switch out to the left. Once out the connector may be tight to get at especially if you have large fingers, but if you gently pull you should be able to get at it enough to squeeze the tab in. The guys at Guy Salmon parts said i'd have to remove the whole plastic trim but this certainly wasn't the case! |
Wed Apr 27 2011 7:20pm |
glad you solved your battery drain took me weeks of testing to get to this problem |
Wed Apr 27 2011 8:06pm |
tomdigym Member Since: 18 Aug 2010 Location: LARBERT Posts: 41 |
Changed mines aswell after reading this thread upper tailgate now works perfect.
Wed Apr 27 2011 8:24pm |
Baron Member Since: 23 Jun 2005 Location: Southener Posts: 529 |
Top thread.
Tue Jul 12 2011 9:16pm |
