Home > General > Suspension totally failing - help
Page 2 of 5 <12345>
RRS_bunny
2010 Range Rover Sport Supercharged Santorini Black
Hi guys
Thanks for all the info. The rangie is totally off the road at the moment as now the coolant system has failed Big Cry It had dumped a whole heap of water\coolant while parked.
I've had the "low coolant" message pop up now and then for a VERY long time, and under warranty had the coolant sensor replaced, the entire bottle assembly etc. So its at Ritter's again while we have a "discussion" with Land Rover about fixing the problem, seeing as it was first raised while under warranty.
Definitely not buying a new one now. Can't justify the spend on a car that is so Censored unreliable. Fortunately we have multiple cars.
Post #275699 Fri Sep 10 2010 6:51am
RRS_bunny
After discussions with various people at Land Rover, they have decided that they don't give a damn about their customers.
I now have a very expensive car that is having major failures only 1 year out of warranty.
Land Rover - you have lost a customer for life.
Land Rover = Customer service FAIL and quality vehicle FAIL. Should have learned from the P38 I had previously - it had so many electrical and suspension problems that we bailed on it.
And the worst thing for you is that an unhappy client will go an tell everyone how bad your product is. Already have a BMW, so will be having a chat with them for our next 4wd purchase. Pity, as we were planning to buy the new RRS supercharged.
Post #275971 Tue Sep 14 2010 10:26am
2nd Rower
Australia 2008 Range Rover Sport TDV6 HSE Chawton White
Sorry to hear this RRS-Bunny,
Can I enquire, have Land Rover and the dealer actually found the root cause of your problems and quoted on a repair, or is it still a case of problems unknown?!
Post #276071 Thu Sep 16 2010 2:29am
RRS_bunny
Hi
They still have the car (for the last week) , so I would suggest that they still trying to fix it.
Post #276140 Fri Sep 17 2010 12:33am
2nd Rower
That seems a positive - let us know how it turns out..
Post #276141 Fri Sep 17 2010 1:01am
RRS_bunny
Terrible.. Just went and picked it up. Should have left it there.
Within the first block, the car was pulling to the right severely. I thought I had a flat tyre. While stopped at the traffic lights, the bonnet then drops down. Some type of suspension issue.....
The car then drove ok, for another 5km, then the suspension totally died. Got the warning lights on the dash, dinging etc. and the car was very very low. Bouncing down the road - it was so bad I had to limp home.
Went to go up the driveway, and the car was so low that the tow bar scraped on the footpath.
I have to wonder if these guys actually did any testing whatsoever- all I did was get in the car and try to drive normally. Didn't touch anything except headlights. Unfortunately I had to pick it up after hours, so couldn't turn around and take it back. VERY Censored off at the moment.
Post #276248 Sat Sep 18 2010 12:43pm
2nd Rower
Doesn't sound good, I hope they are not charging you for all of this...
Post #276275 Sun Sep 19 2010 6:15am
RRS_bunny
Its back at Land Rover again today.............
I hope they aren't expecting me to pay for this - I could have ended up wrapped around a tree or in a nasty accident.
Looks like paying for the compressor to be replaced was a total waste of money.
How are you going with your lemon, 2nd Rower?
Post #276365 Tue Sep 21 2010 2:58am
RRS_bunny
Still don't have my car back. Apparently the suspension failed when a service guy was driving it.......At least they have experienced the problem now.
Post #276781 Tue Sep 28 2010 1:53am
2nd Rower
Have you asked for a loan car yet?
Post #276782 Tue Sep 28 2010 2:21am
RRS_bunny
Yes, we have an awesome loan Volvo.....hardly comparable.
Post #276783 Tue Sep 28 2010 2:35am
2nd Rower
Yes I've had one of them... They told me at the time there were no LR loan cars... But I would later find out that there were some..
Post #276784 Tue Sep 28 2010 4:34am
RRS_bunny
Picked up the car yesterday, apparently it had failed on them several times, and they are sure its fixed now.
Got home last night ok.
Drove to work today, and sure enough, bing - the suspension fault light goes on and it drops to the ground again while I was doing 100km/hr down the freeway. Its a wonder I didn't have a serious accident, as it was bouncing around quite violently. Managed to crawl to work at 40km/hr without being rearended, thank goodness.
The compressor was replaced for the second time in 3 weeks, sensors replaced etc. This is rediculous. Big Cry
Post #277078 Fri Oct 01 2010 4:00am
BKHK
Sounds to me like the dealer is just replacing parts and not properly diagnosing the problem. Continual compressor replacement is unlikely to fix the problem unless the new one was faulty.
Who is your dealer and where are you located? Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Post #277080 Fri Oct 01 2010 5:58am
RRS_bunny
To be fair, they only charged $2k instead of the $6k (they spent a LOT of time on it) but I get the idea that it was a "lets replace everything" kind of fix. Apparently the 2 week old compressor may have "burned out"........
ULR in Melbourne...Was using Ritter, but they couldn't fix it either and handballed it to ULR.
Post #277082 Fri Oct 01 2010 6:05am
Page 2 of 5 <12345>
