Home > Maintenance & Modifications > Battery Drain Fix!!!
baxc
hi guys finally got to the bottom of the battery drain and you wouldnt believe what it was, turned out to be a completely corroded upper tailgate switch. This was pulling a permanent drain from the battery but not releasing the catch coz of the corrosion so wouldnt know this was the problem.
Only found this by accident, its taken me 3 weeks of testing and pulling fuses to find this problem. I would advise anyone with any battery or upper tailgate issue to check their switch by peeling back the rubber, if you have any corrosion you will have problems!!!
New switch �34 plus VAT and 2 mins to fit. Razz Razz
Post #267892 Sat Jun 05 2010 8:57am
Afini
2006 Range Rover Sport TDV6 HSE Bonatti Grey
Hey, i just bought my RRS last week and had the same damn problem. Had it booked in with the stealers to have this batt drain checked out but then came across this post and BINGO! it was that switch! I saved me alot of money thanks to this!!!!
Post #273795 Fri Aug 13 2010 6:54pm
baxc
no probs m8 Thumbs Up
Post #273798 Fri Aug 13 2010 7:25pm
kingjay39
United Kingdom 2005 Range Rover Sport TDV6 HSE Buckingham Blue
Hi i have a battery drain that i was sure was the battery had the RAC out today and they have said that the battery is fine, so was totally confused i saw this post and had a look at the switch , i have managed to pull the rubber off and there is quite a bit of corrosion so i have cleaned it up a bit, the thing is i never had an issue with the tailgate switch and this has been working fine, will this be playing up as well? also how do you get the switch out i cant get the casing out and i cant see any screws anyone have any ideas? cheers J HSE TDV6 running boards colour coded SC grill sidevents and rear tailgate strip and 2010 lights
Post #276362 Mon Sep 20 2010 8:43pm
baxc
hi m8 this could be the cause of your battery drain a new one is about �30 to get it out put a flat screwdriver between the switch and the body of the car and it should clip out Thumbs Up
Post #276422 Wed Sep 22 2010 7:03am
BIG BAD RANGE
ANY CHANCE OF PHOTOS TO SHOW WHAT TO DO
THANKS
Post #276475 Wed Sep 22 2010 8:36pm
m14rsh
Need to change switch also. Could ya do a quick pic of the change over and perhaps a link to the part to buy? Thanks 2014 RRS
Post #276734 Mon Sep 27 2010 6:19am
Tim in Scotland
If you still have warranty left LR will replace the switch under warranty - had my TDV8's whole upper tailgate replaced under warranty to replace the locking mechanism as it was cheaper and quicker for the dealership than stripping the upper section down and replacing the switch and wiring. There was about half a cupful of water inside the upper tailgate on mine which was put down to condensation in the cold weather last winter.
http://www.rrsport.co.uk/forum/topic17072.html 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #276738 Mon Sep 27 2010 9:46am
Bobby
Just pry the switch out and disconnect the electrical connector...
 Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #276742 Mon Sep 27 2010 12:22pm
