Home > General > Problem - Any ideas please?
GIB 984
Hi all,
Jumped in my 56 plate 2.7 HSE this morning and, whilst it was fine last night, I immediately noticed a lack of power when pulling off. I thought at first that my mat had got stuck under the accelerator so pulled over but it hadn't. It is like you are trying to accelerate but the gears arent engaged and then all of a sudden the power comes through. Once you are up to speed you cant notice it but when you slow down and stop at a junction you get the same problem again?
I dont drive quick and normally its only like my foot is resting on the accelerator to give me enough power to pull off. But not now!
Any ideas at all before I slit my wrists!
Thanks for any advice! Best Wishes
Gary
Post #276601 Fri Sep 24 2010 12:11pm
0cj0
I bet some fresh spark plugs & maybe a new coil pack would sort it.
When was it last in for a service?
Post #276604 Fri Sep 24 2010 1:20pm
Bobby
On a diesel?? Shocked Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #276605 Fri Sep 24 2010 1:23pm
Laughing Laughing 2005 Zambezi TDV6 - Gone but not forgotten
Post #276606 Fri Sep 24 2010 1:24pm
GIB 984
It had its second service about 4 months ago? Best Wishes
Gary
Post #276608 Fri Sep 24 2010 1:31pm
Clogged up fuel filter is a possible answer but all these sort of problems seem to revolve around the EGR valves. 2005 Zambezi TDV6 - Gone but not forgotten
Post #276609 Fri Sep 24 2010 1:33pm
GIB 984
Gary
Post #276610 Fri Sep 24 2010 1:35pm
GIB 984
Thanks, are they easily resolved and how much?
It's about 3 hours work for EGR valves IIRC. £120 ph at LR or cheaper at independents. Some people opt for blanking the EGR valves off - they say the performance is better. Best Wishes
Gary
Post #276611 Fri Sep 24 2010 1:36pm
V8 andy
England 2009 Range Rover Sport TDV8 HSE Arctic Frost
Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Gone,,TDV8 arctic frost,black leather,colour coded handles,rear entertainment,sunroof.
1980 Rolls Royce,shadow 2 in white.
Gone 07/57 TDV8 santorino,black leather.chrome handle's/mirror's.
Gone 02/52 FFRR vogue.
Post #276614 Fri Sep 24 2010 2:11pm
chris mc
Scotland 2011 Range Rover Sport TDV8 Autobiography Stornoway Grey
Quote:
A possibly related service bulletin (NASF TSB #LTB00041, Rev 2) entitled "Reduced Power Under Load" appeared, affecting the supercharged versions of the L322/LM and Range Rover Sport/LS Sport vin numbers 6A901924 to 7A109767) The symptom was described as reduced power and or a misfire at high engine loads and road speeds, with the possibility of Diagnostic Trouble Codes (DTC) P0096 and/or P2601 stored. The source of the problem was described as follows: "The electrical harness power supply and ground for the auxiliary coolant pump may be cross connected in connector C3006. The pump will run backwards causing the Engine Control Module (ECM) to reduce power to prevent damage because the pump flow is low. The auxiliary coolant pump will be degraded under these conditions.
Action: Should a customer express concern, modify the wiring at connector C3006 to the correct positions:
• Cavity 1 connected to "-" pump connection Black (B) Brown (N)
• Cavity 2 connected to "+" pump connection Brown / Purple (NP) Red / White (RW)
Install a new supercharger coolant pump as part of the repair if either the fault codes or the incorrect wiring is discovered following the repair."
Update January 2010: Owners continue to experience this problem. Peter White reports his recent experience with his Range Rover Sport Supercharged HST (late 2006 model): "Engine fault warning when accelerating/overtaking on motorway. Happened 3 times in one month. Immediate power loss to limp home mode – very dangerous! Temporarily solved by stopping the vehicle, turning off and removing the key. Dealer suggested software upgrade but later suggested both a software upgrade and replacement supercharger coolant pump and associated wiring following a diagnostic check."
If you experience this problem or know more about the solution please email me.
Is it possible your car could have developed this, i know it is not S/C but still makes interesting reading.
Post #276617 Fri Sep 24 2010 3:24pm
GIB 984
Don't think so as it currently seems to only be when I'm pulling away?
I also filled up yesterday after running it almost down to the fumes showing a 0 miles left to travel in the computer. Could this have caused it? Best Wishes
Gary
Post #276619 Fri Sep 24 2010 3:44pm
If you had sludge in your tank then yes it could be a problem - do you use cheap supermarket diesel? 2005 Zambezi TDV6 - Gone but not forgotten
Post #276620 Fri Sep 24 2010 3:53pm
chris mc
As above if you ran it to the death then i could well be a fueling problem, supermarket fuels are notorious for poor quality.
Maybe worth getting some treatment in it before spending an arm and leg at stealers getting it checked.
Post #276638 Fri Sep 24 2010 8:21pm
GIB 984
Unfortunately yes - morrisons the culprit this time Bow down Best Wishes
Gary
Post #276646 Sat Sep 25 2010 12:06am
MAW
Laughing
Post #276651 Sat Sep 25 2010 7:57am
