![]() | Home > Technical > Replacing AC condenser |
Why are you replacing the condenser core (that's what you want to replace, no?)?
eastwop Member Since: 19 Apr 2008 Location: southampton Posts: 11 ![]() ![]() |
I am replacing it because it has a leak,
Could this be useful? Malaysia Boleh!
Hi thanks for the reply, can you tell me how i can link to the part which says "Remove the radiator assembly.
Ahh.. so its the Radiator you want to remove?
Hi, i need to to replace the AC condenser which is bolted to the Red, i have been told have to remove the Rad, AC condenser and the SC rad together, that why i need to know how to get the RAD out, looking at it, it looks like i need to take it all out from the top,. I am i right.
Just reading the infoamtion about removing the Rad, this helps, the last parts says, after putting it back together, " check the transmisssion level, how is this done,
Unfortunately, there is no RAVE. Malaysia Boleh!
You mean the trans fluid level.. . This is quite tricky. The recommendation is that the fluid level should be checked when the temperature of the fluid is between 30 and 50 degrees! Now, in order to do this you will need to hook-up an LR diagnostic equipment, if you have one. With the engine at idle and the fluid temperature in the recommended range, slowly remove the filler/level plug at the bottom of the gearbox. If no fluid is flowing out, fill the transmission until a small thread of oil runs from the filler/level hole. The trans is now full and level so screw back the plug. Done!! Easy isn't it? ![]() 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
sweetafton Member Since: 05 Dec 2009 Location: Weymouth Posts: 961 ![]() ![]() ![]() |
Bobby how the hell do you know all this stuff. Do you work for LR? You are god in my eyes. |
No Sir, I do not work for LR.
