Home > Technical > Replacing AC condenser
eastwop
Can any one help, does any one have any info on replacing the AC condenser on 2005 RRS 4.2 sc.
i.e removal and replacing a new one
many thanks for any help
Bow down
Post #266918 Sat May 22 2010 3:36pm
Bobby
Why are you replacing the condenser core (that's what you want to replace, no?)?
Is there dirt in the refrigerant circuit or is the system leaking? Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #266939 Sun May 23 2010 12:47am
eastwop
I am replacing it because it has a leak,
does any one have and ideas to to do it.
Post #267064 Mon May 24 2010 4:33pm
Bobby
Could this be useful? Malaysia Boleh!
Post #267084 Mon May 24 2010 8:59pm
eastwop
Hi thanks for the reply, can you tell me how i can link to the part which says "Remove the radiator assembly.
For additional information, refer to Radiator (26.40.01)", i think this is the part i am looking for.
many thanks
Post #267086 Mon May 24 2010 9:30pm
Bobby
Ahh.. so its the Radiator you want to remove?
Good luck! Wink Malaysia Boleh!
Post #267088 Mon May 24 2010 11:38pm
eastwop
Hi, i need to to replace the AC condenser which is bolted to the Red, i have been told have to remove the Rad, AC condenser and the SC rad together, that why i need to know how to get the RAD out, looking at it, it looks like i need to take it all out from the top,. I am i right.
many thanks
Post #267090 Tue May 25 2010 4:58am
eastwop
Just reading the infoamtion about removing the Rad, this helps, the last parts says, after putting it back together, " check the transmisssion level, how is this done,
where can i get access to the Rave manual,
many thanks
Post #267092 Tue May 25 2010 5:10am
Bobby
Unfortunately, there is no RAVE. Malaysia Boleh!
Post #267095 Tue May 25 2010 6:10am
Bobby
eastwop wrote:
.. " check the transmisssion level, how is this done,
You mean the trans fluid level.. .
This is quite tricky. The recommendation is that the fluid level should be checked when the temperature of the fluid is between 30 and 50 degrees! Now, in order to do this you will need to hook-up an LR diagnostic equipment, if you have one.
With the engine at idle and the fluid temperature in the recommended range, slowly remove the filler/level plug at the bottom of the gearbox. If no fluid is flowing out, fill the transmission until a small thread of oil runs from the filler/level hole. The trans is now full and level so screw back the plug. Done!!
Easy isn't it? Smile Malaysia Boleh!
Post #267162 Wed May 26 2010 1:18am
sweetafton
England 2011 Range Rover Sport Supercharged Santorini Black
Bobby how the hell do you know all this stuff. Do you work for LR? You are god in my eyes. Bow down
Post #267167 Wed May 26 2010 7:00am
Bobby
No Sir, I do not work for LR.
Bobby is neither connected to nor affiliated with Land Rover!! Laughing
Just happen to know a little here and there, that's all. Wink Malaysia Boleh!
Post #267218 Wed May 26 2010 10:44pm
