Home > General > Dynamic Response |
rrsboy Member Since: 06 Jan 2009 Location: UK Posts: 1391 |
simply the BEST feature of the car.. also happens to be the BEST feature on the X5 (I forget what they call it but same concept i.e. hydraulic system to act against the torsion (anti-roll) bar on the front of the car), so not sure how or if it could make the whole suspension stiffer i.e. bumps in the road?
Sun Mar 07 2010 4:56pm |
quantz Member Since: 05 Mar 2010 Location: Paris, France Posts: 476 |
Indeed, but as said I'm a smooth driver for my passengers.
Sun Mar 07 2010 5:52pm |
Roland Member Since: 10 Jun 2005 Location: NB Posts: 469 |
$ Couldn't agree more. DR makes a big difference. SOMETIMES YOU'RE THE BUG AND SOMETIMES YOU'RE THE WINDSHIELD 2010 TDV8 Ultimate Edition, zermatt-ebony-grand lacquer, and all the goodies, plus Superchips Bluefin ECU performance upgrade, Gibson Performance exhaust tips gone after only 7 months: MY10 TDV63.0 HSE, zermatt-ebony-anigree, Dynamic Response, Rear diff-lock, flappy paddles, premium leather, Sunroof, PTI, privacy glass, S/C design 5 Spoke Diamond Turned alloys |
Mon Mar 08 2010 5:51am |
ASH555 Member Since: 02 Dec 2006 Location: East Yorkshire Posts: 750 |
You may be a smooth driver but when driving such a tall heavy vehicle such as the RRS it will always benifit from DR, nobody 'speeds' in a RRS buts its suprising how fast you end up 'crusing' through the corners and technical stuff and thats when DR comes into its own
Mon Mar 08 2010 6:24am |
I'm with you, ASH55, but I wonder if the vehicle becomes stiffer and less comfortable. |
Mon Mar 08 2010 8:35am |
Yes, a little stiffer but not uncomfortable.
Mon Mar 08 2010 9:06am |
Dear Bobby,
Mon Mar 08 2010 9:23am |
Cheers!! Malaysia Boleh!
Mon Mar 08 2010 10:51am |
All depends what fast is - nobody drives an RRS likes it's a 911. My RRS didn't have it and it was a bit wallowy, but DR-equipped cars are much tighter. Even if you're not chucking it about you can tell the difference. I go with your dealer... get it, it makes the whole driving experience better in my opinion 2009 Outstanding Contribution Award - Joint Runner Up 2009 'Tech-Head Of The Year' Award - Runner Up Like it here? Then Donate to RRSPORT!! |
Mon Mar 08 2010 10:55am |
Bigby Member Since: 09 Feb 2010 Location: Marlborough, Wiltshire Posts: 83 |
Which raises an obvious question:
Mon Mar 08 2010 1:58pm |
yes, via the fusebox |
Mon Mar 08 2010 2:03pm |
Is it true however, that removing the fuse simply puts it into 'hard mode'. Can it be put into a more default mode similar to not having dynamic response (ie soft and wallowy). 2010MY HSE 3.0 TDV6. Stornoway Grey/Ivory. Extended leather, winter pack. |
Mon Mar 08 2010 2:53pm |
Leo Member Since: 17 Sep 2007 Location: Nomad Posts: 554 |
No, there is no hard mode. DR doesn't affect the damper stiffness. |
Mon Mar 08 2010 7:01pm |
lespes Member Since: 16 Jun 2008 Location: Channel Islands Posts: 1052 |
Landrover guy the other day, who had cmpleted a G4 challenge in RRS was saying that the articulation was far better and improved off-road when fitted with DR which in his book gave it a big advantage over the Disco 3/4 when in the mud |
Mon Mar 08 2010 7:17pm |
