Home > Technical > select `access` then it raises to extended mode ?????????? |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 |
Bad height sensor |
Wed Mar 03 2010 8:54pm |
What happens when you select extended mode? Malaysia Boleh!
Thu Mar 04 2010 1:28am |
Bob. Member Since: 02 Feb 2009 Location: SWest Posts: 275 |
This has happened to me a few times - always found that it works the right way if I look at the rocker switch before pressing it though. |
Thu Mar 04 2010 9:08am |
2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Thu Mar 04 2010 9:11am |
nickspark Member Since: 01 Jan 2010 Location: plymouth Posts: 12 |
but you cannot select extended mode anyway ..............numpty |
Fri Mar 05 2010 8:18pm |
Micrometer Member Since: 26 Nov 2009 Location: Cambridge Posts: 39 |
Its stuck. If you select access and the vehicle drops onto something then it will raise clear of said object. Could that be possible?? Trust me, i'm an Engineer! |
Tue Mar 09 2010 11:34am |
Leo Member Since: 17 Sep 2007 Location: Nomad Posts: 554 |
Someone on disco3.co.uk had the same problem - was an electrical issue, don't remember what. |
Tue Mar 09 2010 1:14pm |
stealer fitted new sensors and compressor........seems ok now. |
Fri Mar 26 2010 7:51pm |
Sat Mar 27 2010 6:38am |
