![]() | Home > Technical > select `access` then it raises to extended mode ?????????? |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 ![]() ![]() ![]() |
Bad height sensor |
What happens when you select extended mode? Malaysia Boleh!
Bob. Member Since: 02 Feb 2009 Location: SWest Posts: 275 ![]() ![]() |
This has happened to me a few times - always found that it works the right way if I look at the rocker switch before pressing it though. |
nickspark Member Since: 01 Jan 2010 Location: plymouth Posts: 12 ![]() ![]() |
but you cannot select extended mode anyway ..............numpty |
Micrometer Member Since: 26 Nov 2009 Location: Cambridge Posts: 39 ![]() ![]() ![]() |
Its stuck. If you select access and the vehicle drops onto something then it will raise clear of said object. Could that be possible?? Trust me, i'm an Engineer! |
Leo Member Since: 17 Sep 2007 Location: Nomad Posts: 554 ![]() ![]() |
Someone on disco3.co.uk had the same problem - was an electrical issue, don't remember what. |
stealer fitted new sensors and compressor........seems ok now. |
