Home > Technical > towbar electrics |
Yes and no! Yes a main dealer will do it for something £100 but many of the Land Rover non franchise specialist garages also have the right autologic systems to be able to do it for a fraction of the cost! The update stops the suspension height being adjusted when it senses there is something plugged into the rear electrics - you loose the access and offroad heights when towing. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Fri Jan 15 2010 8:04pm |
dazsear Member Since: 23 Nov 2008 Location: Lincolnshire Posts: 851 |
Well I never knew that was the reason Tim, I always thought it was to do with the lighting
Fri Jan 15 2010 8:18pm |
Steuart64 Member Since: 24 Dec 2009 Location: Aberdeen Posts: 539 |
IIRC from other posts the software download is also to isolate the fog lights so the glare doesnt reflect from the caravan.
Fri Jan 15 2010 8:41pm |
It also enables that little trailer icon on the dash which I think is to show all your trailer's indicators are working 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Fri Jan 15 2010 8:43pm |
Landlord Member Since: 26 Sep 2006 Location: Hampshire Posts: 607 |
It also immobilises the reversing sensors, so when your reversing with the trailer the rear sensors ignore the trailer. MY10 TDV6 HSE, Alaska White, Ebony with Contrast, Park Heat, Paddle Shift, Privacy, Heated Steering Wheel, Extended & Premium Leather,
Fri Jan 15 2010 9:10pm |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 |
IME
Sat Jan 16 2010 9:53am |
