Home > Technical > towbar electrics
panpicker
England 2007 Range Rover Sport TDV8 HSE Java Black
towbar electrics
Hi all
Im hoping to have both electric plug fitted for towing, but now have been told that once fitted i will have to take the car to Land rover to be plugged into a computer, so that the car recognises that a trailer / caravan is on the back and car can adjust accordingly. is this right ?????????????
Thanks
Post #249995 Fri Jan 15 2010 7:22pm
Tim in Scotland
Yes and no! Yes a main dealer will do it for something £100 but many of the Land Rover non franchise specialist garages also have the right autologic systems to be able to do it for a fraction of the cost! The update stops the suspension height being adjusted when it senses there is something plugged into the rear electrics - you loose the access and offroad heights when towing. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #250005 Fri Jan 15 2010 8:04pm
dazsear
Well I never knew that was the reason Tim, I always thought it was to do with the lighting
Glad I never had mine done then, it sometimes makes loading motorcycles onto my trailer with the height adjusted (alters angle of trailer) on the RRS!
Daz Thumbs Up 2017 4.4 Autobiography FFRR - love this car
Gone - VW T5 Transporter
Long gone - 2009 Disco
Long gone but never out of my thoughts - 2008 TDV8 HST
Post #250008 Fri Jan 15 2010 8:18pm
Steuart64
Scotland 2011 Range Rover Sport 3.0 TDV6 Autobiography Orkney Grey
IIRC from other posts the software download is also to isolate the fog lights so the glare doesnt reflect from the caravan.
Go for the download to get full utilisation and leave the connection unplugged while you load up. Now - MY11 RRS Autobiography TDV6, Orkney gray, tints, steps, daylight running lamps and allllll the toys!!!
Ex- RRS HSE TDV6 07 Java Black, bi xenon, corner lights, side steps, tints, cool box, smoke side repeats, chrome "sport" boot sill
Ex - Audi A4 Cab 3.0TDi Quattro
Ex - Freelander2 SE TD4
Ex - CRV Auto
Post #250011 Fri Jan 15 2010 8:41pm
Tim in Scotland
It also enables that little trailer icon on the dash which I think is to show all your trailer's indicators are working 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #250012 Fri Jan 15 2010 8:43pm
Landlord
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Alaska White
It also immobilises the reversing sensors, so when your reversing with the trailer the rear sensors ignore the trailer. MY10 TDV6 HSE, Alaska White, Ebony with Contrast, Park Heat, Paddle Shift, Privacy, Heated Steering Wheel, Extended & Premium Leather,
MY07 TDV6 HSE, Zermatt Silver, Gone
1964 Austin Healey 3000
2007 LR Defender
2011 VW Tiguan R Line
Post #250020 Fri Jan 15 2010 9:10pm
MAW
IME
The trailer Icon works without the SW update
The reversing sensors were disabled without the update
I was informed the update was to switch off rear fogs
New one about disabling off road - not heard that before but interesting, as Daz says, useful to have ability to select when using a trailer....
In summary you can DIY fit electrics in under an hour an away you go - UNLESS MY10 onwards has been setup differently, I have fit electrics to a 55(MY??) plate and a 58(MY09) plate with no issues Thumbs Up
That rear fog glare is there to remind you that you shouldn't have a caravan Whistle Laughing
Post #250059 Sat Jan 16 2010 9:53am
