![]() | Home > General > got stuck in snow.. question on technique/cause |
SkyWalker Member Since: 04 Sep 2009 Location: Marbella Posts: 540 ![]() ![]() ![]() |
ENDJIN,
npinks Site Moderator Member Since: 26 Nov 2007 Location: Watching Posts: 6716 ![]() ![]() |
i think socks/chains are good if you can get them on prior to been stuck, in the deep snow pictured
I found them for sale at http://www.outdoorbits.com/jeko-universal-...p-775.html but haven't purchased any yet as I haven't taken my FL2 snowboarding yet |
Endjin, up today I have been running on my 20's on the TDv8 and they have coped with everything very well. I'm running on Pirellis that the factory fits as standard and they are down to 3mm tread on one tyre 4 on all the others (confirmed today by the wheel fitter who I asked to check the tread depth now the wheels and tyres are off the car)
Endjin Member Since: 22 Jun 2007 Location: Aberdeenshire Posts: 2087 ![]() ![]() |
Cheers for all the input chaps |
Good find!
JonnyDangerous Member Since: 09 Nov 2009 Location: Reading Posts: 57 ![]() ![]() ![]() |
Happened to me today in what i thought would be bread and butter conditions for the RRS. I had the same problem, standing still and one of the wheels spinning going no where. Do these cars not come with a differential to avoid this happening? I'm sure i can remember seeing on the 4x4 screen on my MY10 some padlocks indicating a locking diff but when i've gone back and looked again i don't see these any more. Is there a way you can force power to all four wheels? |
Josh Member Since: 24 Dec 2005 Location: Here, there and everywhere Posts: 2054 ![]() ![]() |
Locking diff was a factory extra on mine which I took and I beleive it was a standard fit on the SC.
ViewWise Member Since: 13 Mar 2008 Location: London Posts: 704 ![]() ![]() ![]() |
See the thread on the LR snow solution http://rrsport.co.uk/forum/topic16316.html
I've got SnowSocks in 275 40 20 size.
Leo Member Since: 17 Sep 2007 Location: Nomad Posts: 554 ![]() ![]() |
Going for a LRE day will help teach how to use the various settings etc - bit late now, but good for the future. |
lespes Member Since: 16 Jun 2008 Location: Channel Islands Posts: 1052 ![]() ![]() ![]() |
not 100 percent but sure the diff locks only light up when they are activated all done electronically. Have been out all day, 18 inch All terrains, GGS mode high range all the way not a problem through deep virgin snow, large hill climbs with good hard compacted snow and some trtacks with large drifts along the way. Used command shift mode on steep descents for engine braking rather than using brakes, worked very well. A trick used on the TD5 Discoveries was to pump the brake pedal hard and fast as the traction control can become confused and this used to help unconfuse it. Have not had to resort to this yet as the traction control on the RRS is way superior. Finally if in a sticky situation REMEMBER to switch the DSC control OFF and those who have rear locking diffs as well this will make a bigger difference than those without. |
sportdriver Member Since: 21 Nov 2009 Location: Dorset Posts: 63 ![]() ![]() |
When I put mine in GGS Mode the 2 x green padlocks indicate the diffs are locked.
Thanks! I didn't know this. My car has been in GSS mode for a few days. Now i know i have to re-select it every time i start! |
Glad to help - hope this works the same on yours!! '10 Jaguar XKR Coupe 5.0L Supercharged.
