Home > General > got stuck in snow.. question on technique/cause
Page 1 of 3 123>
rrsboy
2010 Range Rover Sport TDV8 HSE Santorini Black
it may just be the tyres (20" Toyo's)....
but had a whale of a time on Salisbury Plain in the mud, no signs of getting stuck.. drove through the snow for a good few hours before finally getting firm stuck:
had her in low range, terrain response set to mud/snow, DSC turned off, gear 2 using command shift... but couldn't get ANY traction
is there anything I could have/should have done differently? would different tyres have *really* helped here?
cheers
Post #247888 Tue Jan 05 2010 9:13pm
RichardM
2010 Range Rover Sport TDV8 HSE Galway Green
I've too had been disappointed with the traction in the snow with the standard 20" tyres. Got me wondering would the locking differential option make a big difference? It seemed just one wheel on each axle was spinning when I got stuck.
Did you get the car out eventually mate? WINNER - 2009 ‘Just Doing What It’s Designed To Do’ Award
2010 TDV8 HSE Galway Green - Adaptive Cruise - Sunroof - Privacy Glass - 5 Spoke Alloys
2009 TDV6 3.0 HSE Buckingham Blue - GONE
Post #247893 Tue Jan 05 2010 9:18pm
rrsboy
yeah.. bloody Mitsi Warrior rescued me!!
Post #247895 Tue Jan 05 2010 9:22pm
RichardM
Thankfully 3 guys rescued me by helping push me forward. I had got stuck trying to rescue a colleague in an Astra. WINNER - 2009 ‘Just Doing What It’s Designed To Do’ Award
Post #247897 Tue Jan 05 2010 9:29pm
Tim in Scotland
The problem is your tyres - the treads just clog too quickly in those conditions and end up as slicks, no amount of electronics can get you out of that! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #247907 Tue Jan 05 2010 9:56pm
Lookers Park Royal
As Tim says....... Tyres!
The tread gets clogged then you polish the snow under the tyre.
They did perform well on a muddy Sailsbury Plain, I can vouch for that as I was there! (in a Defender).
James Thumbs Up
Post #247910 Tue Jan 05 2010 10:03pm
bulldog-winston
United Kingdom 2007 Range Rover Sport TDV6 S Java Black
Popped down to my local garage today with my unused 18ins alloys complete with the all weather tyres in the boot to swap them for the 20ins alloys that were on her. Bit of a palava but sure it will be well worth it. Just waiting for some snow now !!!!
Will swap them back again when the sun comes out !!
Post #247913 Tue Jan 05 2010 10:16pm
tyres and it can even happen with winter tyres..... had that a while ago Sad
Post #247931 Wed Jan 06 2010 8:32am
C10CKO
I've currently got a set of 19" on eBay. Perhaps I should consider pulling the auction and keeping for the winter months.
Regards,
C10CKO MY12 RRSport 3.0 SDV6 Autobiography
Orkney | Everything | Dynamic Pack | Park Heating | Cold Climate Pack | Privacy Glass | Extended Leather | 20inch alloys
Post #247940 Wed Jan 06 2010 8:40am
diamond
Greece 2009 Range Rover Sport TDV6 SE Alaska White
I believe that only mud tyres can handle that kind of situation 2009 Range Rover Sport 2.7 TDV6 SE, Alaska White, Almond leather, tinted windows, active rear diff, tow pack, HiICE, full spare: gone and already missed
2004 Fiat Panda 1.2 Climbing 4x4
http://www.youtube.com/watch?v=fAg4DdXAp7Y
Post #247949 Wed Jan 06 2010 8:58am
Alicatt
Belgium 2008 Range Rover Sport TDV8 HSE Buckingham Blue
Mud tyres are good for snow but not so good on ice, proper snow ice tyres are siped (small cuts in the tread) allowing the tread blocks to move more and helps the tyres stick to the ice. for more extreme ice/snow you can get tyres with studs (usually tungsten) that bite into the ice to provide grip, I've seen them used in Norway. Sons of dogs come hither and get flesh
Clan Cameron
Post #247953 Wed Jan 06 2010 9:11am
Endjin
Scotland
As a temporary easy On/off solution, wouldn't a set of snow chains have helped in RRSBOY's situation?
I would welcome comments on this idea as I'm thinking of buying a set for the new RRS when it arrives
in a few days as it has the 20" wheels whereas my current one has 19's. 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black
2013 Evoque 5 Door Pure Tech SD4 - Orkney Grey with Panoramic Roof (Mrs E's new baby)
GONE - RRS - 3.0 TDV6 HSE - Santorini (2010)
GONE - RRS - 2.7 TDV6 HSE - Java Black (2007)
GONE - Porsche Boxster S - 3.2 - Black
Post #247979 Wed Jan 06 2010 10:26am
snow chains are the easy way out Smile
Post #247982 Wed Jan 06 2010 10:29am
Lookers Park Royal
LR don't advise snow chains with 20" wheels. I am told it's to do with clearance at the rear between the chains and airbags for the suspension.
James Thumbs Up
Post #248009 Wed Jan 06 2010 12:13pm
wardpg
James
You can put snow chains on the front wheels as per the RRS accessory catalogue, they are available for 18, 19 and 20 inch wheels
Post #248013 Wed Jan 06 2010 12:50pm
Page 1 of 3 123>
