![]() | Home > Technical > MY10 heated front & rear screens |
Richchad Member Since: 04 Apr 2006 Location: Oxfordshire Posts: 285 ![]() ![]() |
Just noticed that the front and rear screens switch on automatically if temperature is low, which is fine if it is parked outside but seems a bit pointless when it has been parked in a garage or carport and windscreens are nice and clear which means I have to turn them both off each time I start in cold weather
ASH555 Member Since: 02 Dec 2006 Location: East Yorkshire Posts: 750 ![]() ![]() ![]() |
I learn more every day |
It doesn't give temperature figure in the manual, just says when it is low temperature, think it might be 5 degrees as that was when the little snowflake symbol used to show before in my 2006 model. Didn't give any indication in the manual if you can turn off this option either, has anyone found out if you can? https://www.plus.net/refer.php?strReferral...d093cba6a7 Gone - RRSPORT TDV6 HSE Buckingham Blue/Ivory, Privacy Glass, Tasmods Sills, Supercharged Black Badges all round, Grille & Vents, plus RRSport Sticker & Brolly of course. |
RichardM Member Since: 24 Sep 2009 Location: Herts Posts: 745 ![]() ![]() |
I think its a great feature, but the last few times it has come on in mine it hasn't been in the least bit frozen. WINNER - 2009 ‘Just Doing What It’s Designed To Do’ Award
viper Member Since: 21 Apr 2007 Location: chester le street Posts: 857 ![]() ![]() ![]() |
Must admit it a waste coming on when been in garage overnight but still usefull and its easy to press the two turn off switches when not needed |
It would be easier to press the two switches to turn it on when you need it ![]() Good idea but it should be a selectable option really.. ![]() Gone - RRSPORT TDV6 HSE Buckingham Blue/Ivory, Privacy Glass, Tasmods Sills, Supercharged Black Badges all round, Grille & Vents, plus RRSport Sticker & Brolly of course. |
Landlord Member Since: 26 Sep 2006 Location: Hampshire Posts: 607 ![]() ![]() ![]() |
Think the heated mirrors are the same, only come on when its cold enough. IIRC pre 10MY they used to come on with the front screen.
MY10 TDV6 HSE, Alaska White, Ebony with Contrast, Park Heat, Paddle Shift, Privacy, Heated Steering Wheel, Extended & Premium Leather, MY07 TDV6 HSE, Zermatt Silver, Gone ----------------------------- 1964 Austin Healey 3000 2007 LR Defender 2011 VW Tiguan R Line |
Well as I have mentioned in another post I did quite a bit of driving today, stopping and starting a lot and every time I started her up on come all the heaters which you certainly don't need once the car is warmed up.
