![]() | Home > Technical > Was told it was EGR vales now its maybe the turbo |
often the two faults are related - EGR goes and Turbo fails soon after, or the other way round. If you use the search tool on the tool bar and search on EGR or "turbo" you will find plenty of posts about this problem. you can also join the sister forums www.disco3.co.uk and there are numerous posts there about this quite common TDv6 problem 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
lespes Member Since: 16 Jun 2008 Location: Channel Islands Posts: 1052 ![]() ![]() ![]() |
Though turbo failure is not uncommon in these their is also a pipe that tends to split as well and cause loss of power etc.
Davie Low Member Since: 12 Dec 2009 Location: Aberdeen Posts: 17 ![]() ![]() ![]() |
Thanks for your feedback.
lrdaft Member Since: 29 Mar 2009 Location: scotland Posts: 43 ![]() ![]() ![]() |
normally egr valve faults will not bring on engine fault warnings,just loss of power
turbo retails at £888plus vat plus labour
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 ![]() ![]() ![]() |
A sponsor was selling turbos at a good £ IIRC recently - do a search - may have been bell autos |
Thanks for the replys guys. |
