Home > Technical > Was told it was EGR vales now its maybe the turbo
Davie Low
Scotland 2006 Range Rover Sport TDV6 HSE Alaska White
Hopefully some one can help or advise me on this matter.
My RRS has given me no problems over the last few years, but last week after a long journey, the following morning it came up with a engine system failure.
I took it to the local dealer where they told me it was the EGR valves, ive since had them replaced but there is another fault with the turbo now.
Im not 100% sure of the fault as im offshore at the moment getting information from my girlfriend. The fault is something like turbo circuit pressure low, to me that does not sound mechanical which a turbo is but an actuator or a wiring fault on the boost side. There isn't blue smoke or any normal signs of turbo failure. Hopefully someone can help.
Many thanks.
Post #245214 Sat Dec 12 2009 7:18pm
Tim in Scotland
often the two faults are related - EGR goes and Turbo fails soon after, or the other way round. If you use the search tool on the tool bar and search on EGR or "turbo" you will find plenty of posts about this problem. you can also join the sister forums www.disco3.co.uk and there are numerous posts there about this quite common TDv6 problem 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #245216 Sat Dec 12 2009 7:26pm
lespes
Guernsey 2006 Range Rover Sport TDV6 HSE Buckingham Blue
Though turbo failure is not uncommon in these their is also a pipe that tends to split as well and cause loss of power etc.
Look up posts Tim suggested.
Hope its a pipe as turbos are expensive if out of warranty
Post #245235 Sat Dec 12 2009 8:52pm
Davie Low
Thanks for your feedback.
I'll have a look at the posts mentioned.
Guess i'll just have to wait till i get home to check the pipes out myself.
Any idea how much a turbo costs for a RRS?
Ive also heard of actuator faults, but i was told that they don't come seperate from the turbo unit, is this correct?
Post #245240 Sat Dec 12 2009 10:11pm
lrdaft
Scotland 2005 Range Rover Sport TDV6 HSE Bonatti Grey
normally egr valve faults will not bring on engine fault warnings,just loss of power
have changed turbo on disco 3 not much fun - burner out to cut off studs or body off!!!!!!!!!!!!!!!
Post #245297 Sun Dec 13 2009 7:26pm
lrdaft
turbo retails at £888plus vat plus labour
the engine ecu needs reprogramed to protect new wastegate from being pushed out too far & sticking like your old unit
Post #245299 Sun Dec 13 2009 7:31pm
MAW
A sponsor was selling turbos at a good £ IIRC recently - do a search - may have been bell autos
Post #245301 Sun Dec 13 2009 7:35pm
Davie Low
Thanks for the replys guys.
Post #245304 Sun Dec 13 2009 7:59pm
