![]() | Home > Technical > Rear Interior Lights (map lights?) |
crowej Member Since: 21 Apr 2008 Location: Dublin Posts: 289 ![]() ![]() ![]() |
yup its possible, there is a tutorial on here somewhere but it is quite involved. you have to run wires solder on to switches etc. |
acowx Member Since: 21 Jun 2009 Location: New Freedom Posts: 61 ![]() ![]() ![]() |
I saw the other posts but the link is broken, does anyone else have the original content ? |
CarlW Member Since: 15 Jan 2008 Location: Lanarkshire Posts: 22 ![]() ![]() ![]() |
I did this mod last year using the instructions downloaded from this site. I've placed a copy of the instructions in my gallery
Carl,
Hi Andy,
SilverspeedRRS Member Since: 29 Jun 2007 Location: Leicestershire Posts: 95 ![]() ![]() ![]() |
This was a must do for MY10. Guess what they didn't do it! |
Carl,
Hi Andy,
One last question (hopefully)... does anyone know which fuse is used to control the puddle lamps and the lamps on the bottom of the doors ? The owners manual isn't really much help with the descriptions.
Modification completed this morning !
pex18 Member Since: 03 Dec 2008 Location: Verona Posts: 6 ![]() ![]() ![]() |
Hi, did you do the same also on the right side? I mean, the green/white cable is in the same position (facing right) as on the left side of the car. Just to know if I've to take it on the left as on the guide on the CarlW Gallery. Hope you can understand my bad English and what I mean! Thanks |
purple people eater Member Since: 10 Dec 2009 Location: Miles beyond midlife crisis Posts: 990 ![]() ![]() |
I can not believe that the rear cabin lights do not have a courtesy setting for entry/exit door opening. Is the modification difficult, being a pen pusher who struggles to fit a light bulb at home, is there anyone out there who would do it, do landrover modify? purple people eater
PPE - there are courtesy lights in the rear doors.............................................. just that in Land Rover's mind it is nicer to have them in the bottom of the rear doors to illuminate the big cow pat you are about to step into rather than the seat you want to sit in! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
