Home > Technical > Rear Interior Lights (map lights?)
acowx
United States 2006 Range Rover Sport Supercharged Rimini Red
Guys,
Is there a way to get lighting in the rear cabin when the doors are open ?
The back of my RR is pitch black (apart from the light above the mirror in the front) when I open the doors, is there a way to get those map lights to come on when the doors are open ?
Thanks !
Post #242843 Sun Nov 15 2009 12:08am
crowej
Ireland 2006 Range Rover Sport TDV6 HSE Java Black
yup its possible, there is a tutorial on here somewhere but it is quite involved. you have to run wires solder on to switches etc.
Post #242852 Sun Nov 15 2009 8:29am
acowx
I saw the other posts but the link is broken, does anyone else have the original content ?
Post #242861 Sun Nov 15 2009 12:48pm
CarlW
Scotland 2008 Range Rover Sport TDV8 HSE Java Black
I did this mod last year using the instructions downloaded from this site. I've placed a copy of the instructions in my gallery
Good luck
Carl
Post #243014 Tue Nov 17 2009 3:41pm
acowx
Carl,
Thanks for that. Did you use the same approach (cutting into the sheath of the violet wire also also clipping the new wire under the clamp of the courtesy light bulb holder) ?
How long did it take you per side ?
Andy
Post #243083 Wed Nov 18 2009 9:21am
CarlW
Hi Andy,
It's a little while ago that I did this so it's not fresh in my mind. I recall that fishing the wire through from the centre column to the rear side light was probably the most fiddly part of the process, I made the connection to the purple wire only on one side of the car, I fished a wire across the roof to connect the two lights together rather than going to the trouble of making connections at the bottom of both 'B' pillars. I soft soldered the connections to both the purple wire and also to the bulb holder part of the light fitting (rather than relying on the wire between the bulb and the holder) - I also added two diodes - one at each light - the result is that all 3 lights come on when you open the doors, all 3 come on when you turn the front courtesy light on, but each of the rear lights comes on by itself when you use the switches on the rear lights. I think I spent most of a day on it - probably about 6-8hrs but I'm sure it could be done quicker.
Regards
Carl
Post #243096 Wed Nov 18 2009 12:01pm
SilverspeedRRS
United Kingdom 2012 Range Rover Sport SDV6 Autobiography Sumatra Black
This was a must do for MY10. Guess what they didn't do it!
Post #243105 Wed Nov 18 2009 2:50pm
acowx
Carl,
Thanks for the info, where exactly did the diodes link in ? (I'm guessing between the new wire and the connection to the bulb holder) ?
Andy
Post #243108 Wed Nov 18 2009 3:39pm
CarlW
Hi Andy,
Yes between the new wire and the bulb holder - I've just taken a couple of photos of mine and added the to my gallery - you can just see the diode
Carl
Post #243120 Wed Nov 18 2009 8:49pm
acowx
One last question (hopefully)... does anyone know which fuse is used to control the puddle lamps and the lamps on the bottom of the doors ? The owners manual isn't really much help with the descriptions.
I pulled F1 but that seems to control the rear interior lamps and the center overhead console switched lights only.
Thanks
Post #243268 Fri Nov 20 2009 7:59pm
acowx
Modification completed this morning !
Thanks to all who read/commented and provided advice, thanks also to the original poster who documented the process !!
Makes a hell of a difference when you have black-out windows all round, I can see what I'm doing now !
Post #243300 Sat Nov 21 2009 4:28pm
pex18
Italy 2007 Range Rover Sport TDV8 HSE Lugano Teal
Hi, did you do the same also on the right side? I mean, the green/white cable is in the same position (facing right) as on the left side of the car. Just to know if I've to take it on the left as on the guide on the CarlW Gallery. Hope you can understand my bad English and what I mean! Thanks
Post #243719 Wed Nov 25 2009 8:55pm
acowx
Yeah, I did exactly the same on both sides, green/white wire swapped in the connector at the courtesy light and spliced into the purple wire at the bottom of the pillar.
I must have dislodged something at the RF sensor, people tell me it's in the pillar or the roof but I'm at a loss to the exact location....
Is there an antenna for the RF receiver in the window glass, perhaps I dislodged that ???
Help !
Andy
Post #243727 Wed Nov 25 2009 10:28pm
purple people eater
I can not believe that the rear cabin lights do not have a courtesy setting for entry/exit door opening. Is the modification difficult, being a pen pusher who struggles to fit a light bulb at home, is there anyone out there who would do it, do landrover modify? purple people eater
There are no good days, just some days that are not as bad as others!
Gone RR 4.0 P38 Autobiography MY99 Red ( Evil or Very Mad money pit)
Gone Big Cry RRS MY06 2.7TDV6 HSE Rimini Red
Gone RRS MY10 3.0TDV6 HSE Bali Blue with lots of bits (never grew to love it)
Here Now - 3.6 TDV8 FFRR OVERFINCH Stornoway Grey - loving it x
My work car Ford Mondeo 2.0 TDci Zetec auto Estate in Silver
Post #245020 Thu Dec 10 2009 1:51pm
Tim in Scotland
PPE - there are courtesy lights in the rear doors.............................................. just that in Land Rover's mind it is nicer to have them in the bottom of the rear doors to illuminate the big cow pat you are about to step into rather than the seat you want to sit in! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #245042 Thu Dec 10 2009 6:16pm
