Home > Technical > Winter's coming... ...expect suspension warnings. |
CADjockey Member Since: 03 Feb 2009 Location: West Midlands Posts: 36 |
Having had my flying brick since November last year, I had a few instances, on very cold nights, when
Wed Sep 23 2009 10:26am |
2nd Rower Member Since: 12 Nov 2007 Location: Upside Down Posts: 1382 |
Check your battery.. May need charging, may need replacing.. I was told by the dealer that just driving won't charge and to use a charger overnight..
Wed Sep 23 2009 10:38am |
Alias Member Since: 18 Aug 2009 Location: Zürich Posts: 194 |
I will have a lot of problem with the cruise control. |
Wed Sep 23 2009 10:47am |
I drive about 115 miles a day, I would think that should keep her charged, but I'll get the men that know to have a check the next time she goes in for a little love. And before I forget... Christmas tree! |
Wed Sep 23 2009 3:08pm |
Alicatt Member Since: 11 Jun 2007 Location: Eating in Eksel or Ice cold in Alex Posts: 1435 |
When I wasn't using the RRS much I left a solar charger connected and that kept the battery topped up. Never had any problems in cold weather with mine, it was great fun driving in -27c with snow up to the doors Sons of dogs come hither and get flesh
Wed Sep 23 2009 4:29pm |
lespes Member Since: 16 Jun 2008 Location: Channel Islands Posts: 1052 |
might be worth fitting an auxillary battery. |
Wed Sep 23 2009 6:10pm |
Yes - as in lit up like a.... I had several warning lights across the dashboard, the screen reported: suspension fault, then park brake fault, then gearbox fault... I drove straight to the dealer and they said the computer was reporting low charge in the battery. That I should charge it overnight, and if that didn't fix it, then I would likely have to replace the battery. I believe it is also well known that cold weather puts extra strain on a battery. Lespes' suggestion is a good one... I will do this at some point. I am amazed Land Rover don't offer it as an option! |
Wed Sep 23 2009 9:52pm |
Maybe I can insulate the battery??? |
Sun Oct 04 2009 6:52pm |
If the computer can detect and store a fault code for low battery charge, then why don't they have the information screen report this rather than all the other errors that report when the Can Bus has a low current. |
Sun Oct 04 2009 9:13pm |
There is this TSB which may be of use.
Sun Oct 04 2009 10:10pm |
