Home > Technical > Winter's coming... ...expect suspension warnings.
CADjockey
United Kingdom 2007 Range Rover Sport TDV6 HSE Zermatt Silver
Having had my flying brick since November last year, I had a few instances, on very cold nights, when
starting her up at about 6am (usual daily time) I got suspension failure warnings on the dash. If I ran
her for a bit, stopped and restarted (and I'm assuming she's warmed up a bit) the error went away.
I imagine that it will happen again when it gets cold again. Anyone experienced anything similar?
Post #237737 Wed Sep 23 2009 10:26am
2nd Rower
Australia 2008 Range Rover Sport TDV6 HSE Chawton White
Check your battery.. May need charging, may need replacing.. I was told by the dealer that just driving won't charge and to use a charger overnight..
I had a full Christmas tree on the dashboard a couple of weeks ago (inc suspension fault) due to low battery charge!
Post #237740 Wed Sep 23 2009 10:38am
Alias
Switzerland 2006 Range Rover Sport TDV6 HSE Java Black
I will have a lot of problem with the cruise control. Sad
Post #237743 Wed Sep 23 2009 10:47am
CADjockey
I drive about 115 miles a day, I would think that should keep her charged, but I'll get the men that know to have a check the next time she goes in for a little love. And before I forget... Christmas tree! Exclamation
Post #237781 Wed Sep 23 2009 3:08pm
Alicatt
Belgium 2008 Range Rover Sport TDV8 HSE Buckingham Blue
When I wasn't using the RRS much I left a solar charger connected and that kept the battery topped up. Never had any problems in cold weather with mine, it was great fun driving in -27c with snow up to the doors Smile Sons of dogs come hither and get flesh
Clan Cameron
Post #237792 Wed Sep 23 2009 4:29pm
lespes
Guernsey 2006 Range Rover Sport TDV6 HSE Buckingham Blue
might be worth fitting an auxillary battery.
Post #237802 Wed Sep 23 2009 6:10pm
2nd Rower
Yes - as in lit up like a.... Laughing
I had several warning lights across the dashboard, the screen reported: suspension fault, then park brake fault, then gearbox fault... I drove straight to the dealer and they said the computer was reporting low charge in the battery. That I should charge it overnight, and if that didn't fix it, then I would likely have to replace the battery.
I believe it is also well known that cold weather puts extra strain on a battery.
Lespes' suggestion is a good one... I will do this at some point. I am amazed Land Rover don't offer it as an option!
Post #237828 Wed Sep 23 2009 9:52pm
CADjockey
Maybe I can insulate the battery???
Post #239023 Sun Oct 04 2009 6:52pm
Supacat
Just had my 45k mile service and this was a fault code in mine. Quite surprising as it's not had alot of high current draw - at least not compared to what it will get in the winter - and my daily commute is a m-way run of 112 miles, so that should be plenty good enough to ensure the battery gets fully charged.
Are the batteries being fitted just rubbish?
Post #239031 Sun Oct 04 2009 8:47pm
2nd Rower
If the computer can detect and store a fault code for low battery charge, then why don't they have the information screen report this rather than all the other errors that report when the Can Bus has a low current.
Post #239035 Sun Oct 04 2009 9:13pm
2nd Rower
There is this TSB which may be of use.
http://www.alldata.com/tsb/LandRover/12441.../2151.html
Given that my battery low voltage came from nowhere, and that since the recharge the battery has been perfectly fine, I suspect this could be my issue.
Post #239038 Sun Oct 04 2009 10:10pm
