Home > Technical > Squeeky suspension |
Trev Member Since: 11 Sep 2008 Location: Home-Hartlepool, Work-Rotterdam, Holland Posts: 53 |
Wonder if anyone else has had the same problem.
Wed Sep 16 2009 1:27pm |
Ok thanks i'll check that one out at my next pitstop. cheers. Supercharged 2006 gone
Thu Sep 17 2009 11:47am |
mccalia1 Member Since: 09 Aug 2009 Location: UK Posts: 368 |
Let us know how you get on Gone: RRS : HSE : TDv6 : 57 : Java Black : Ebony : 20" |
Thu Sep 17 2009 6:28pm |
bermyandy Member Since: 09 Sep 2007 Location: London Posts: 336 |
Is it there all the time, or tends to start about 15-20 minutes after starting to drive? |
Fri Sep 18 2009 8:00am |
No it's there all the time, obviously it's worse when i go slow and over uneven ground, or over a bump in the road, the only way i can stop it is put my windows up and turn the music up that seems to help Supercharged 2006 gone
Fri Sep 18 2009 11:07am |
Alicatt Member Since: 11 Jun 2007 Location: Eating in Eksel or Ice cold in Alex Posts: 1435 |
The suspension on mine started to squeak after about 40k km, the garage here replaced the bushings under waranty and now the squeak is gone Sons of dogs come hither and get flesh
Fri Sep 18 2009 12:31pm |
Back home to England next month for 5 days so i'll get it checked there, things are a lot cheaper at home than over here on the continent, so bloody expensive over here for everything compared to home. hopefully the squeeking will be stopped soon Supercharged 2006 gone
Fri Sep 18 2009 12:40pm |
