![]() | Home > Technical > Squeeky suspension |
Trev Member Since: 11 Sep 2008 Location: Home-Hartlepool, Work-Rotterdam, Holland Posts: 53 ![]() ![]() ![]() |
Wonder if anyone else has had the same problem.
Ok thanks i'll check that one out at my next pitstop. cheers. Supercharged 2006 gone
mccalia1 Member Since: 09 Aug 2009 Location: UK Posts: 368 ![]() ![]() ![]() |
Let us know how you get on |
bermyandy Member Since: 09 Sep 2007 Location: London Posts: 336 ![]() ![]() |
Is it there all the time, or tends to start about 15-20 minutes after starting to drive? |
No it's there all the time, obviously it's worse when i go slow and over uneven ground, or over a bump in the road, the only way i can stop it is put my windows up and turn the music up that seems to help |
Alicatt Member Since: 11 Jun 2007 Location: Eating in Eksel or Ice cold in Alex Posts: 1435 ![]() ![]() ![]() |
The suspension on mine started to squeak after about 40k km, the garage here replaced the bushings under waranty and now the squeak is gone |
Back home to England next month for 5 days so i'll get it checked there, things are a lot cheaper at home than over here on the continent, so bloody expensive over here for everything compared to home. hopefully the squeeking will be stopped soon |
