Home > Technical > Squeeky suspension
Trev
United Kingdom 2010 Range Rover Sport Supercharged Santorini Black
Squeeky suspension
Wonder if anyone else has had the same problem.
My front suspension squeeks like hell, which is slightly embarrasing as it sounds like an old banger driving down the street, i've had it to the local garage who say nothing is wrong with it and they lubricated everything they could, never stopped the problem.
Just passed it's MOT last week with no problems and again got this different garage to check and they did the same as the previous garage with no result. anybody have a clue what it is or how i can get rid of this irritating sound?
Post #236959 Wed Sep 16 2009 1:27pm
mccalia1
If they've been checked and given the thumbs up, are you sure it's not something else from that area?
I had a slight rumbling/knocking/squeaky sound when driving, found out they were the anti roll bar bushes which were worn.
Have you had these checked? Gone: RRS : HSE : TDv6 : 57 : Java Black : Ebony : 20"
Post #236999 Wed Sep 16 2009 5:47pm
Trev
Ok thanks i'll check that one out at my next pitstop. cheers. Supercharged 2006 gone
Supercharged Overfinch 2010 on the drive:)
Post #237097 Thu Sep 17 2009 11:47am
mccalia1
Let us know how you get on Thumbs Up Gone: RRS : HSE : TDv6 : 57 : Java Black : Ebony : 20"
Post #237148 Thu Sep 17 2009 6:28pm
bermyandy
2013 Range Rover Sport Supercharged Zermatt Silver
Is it there all the time, or tends to start about 15-20 minutes after starting to drive?
Post #237215 Fri Sep 18 2009 8:00am
Trev
No it's there all the time, obviously it's worse when i go slow and over uneven ground, or over a bump in the road, the only way i can stop it is put my windows up and turn the music up that seems to help Big Cry Supercharged 2006 gone
Post #237262 Fri Sep 18 2009 11:07am
Alicatt
Belgium 2008 Range Rover Sport TDV8 HSE Buckingham Blue
The suspension on mine started to squeak after about 40k km, the garage here replaced the bushings under waranty and now the squeak is gone Thumbs Up Sons of dogs come hither and get flesh
Clan Cameron
Post #237276 Fri Sep 18 2009 12:31pm
Trev
Back home to England next month for 5 days so i'll get it checked there, things are a lot cheaper at home than over here on the continent, so bloody expensive over here for everything compared to home. hopefully the squeeking will be stopped soon Thumbs Up Supercharged 2006 gone
Post #237280 Fri Sep 18 2009 12:40pm
