Home > General > TIME TO BRING TO DEALER ?? |
Small squirt of WD40 or 3in1 into the fuel flap spring might cure that problem.
Thu Aug 06 2009 3:46pm |
Jonty Member Since: 11 Mar 2008 Location: Sat with my head in my hands wondering what the hell I'm doing Posts: 508 |
All look like warranty issues to me.......except maybe the electric window switch either way dealer will advise....
Thu Aug 06 2009 3:47pm |
Yes, get them all sorted under warranty pronto.
Fri Aug 07 2009 8:31am |
RALLYMAN1984 Member Since: 14 Jul 2009 Location: Manchester Posts: 8 |
Another niggle I noticed, was the Spare Wheel mechanism has ker-nack-erd up, wont drop down...
Tue Aug 11 2009 4:16pm |
Is your car purchased as a Land Rover Approved Used Car Rallyman? Because if it was then the supplying dealer doesn't appear to have done a very good job of the Approved Used checks or prepping the car for the forecourt. Maybe you should take this up with them? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Tue Aug 11 2009 4:24pm |
Hi Tim,
Mon Aug 17 2009 3:43pm |
Are you in or out of warranty, because I see on your avatar you have a 2006 car? If in warranty take it to a dealer and try them, if out then get hold of one of the Land Rover magazines in WH Smith and look for an indy in your area, if no joy there then go to www.landrovernet.com and ask if anybody there can recommend an indy in your area. The other place to look is on our sister site www.dsico3.co.uk as many D3's are out of warranty now and I'm sure there are folks there who will be able to tell you of an indy, if you are close enough for him to travel to you the 10forcash is always highly recommended - he's a travelling mechanic who knows how to fix most ills that RRS and D3 suffer from - IIRC he is a registered user here too so you can do a membership search for him 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Mon Aug 17 2009 7:10pm |
islider Member Since: 19 Jun 2009 Location: Deepest Darkest Hedgeland Posts: 457 |
Rallyman1984
Mon Aug 17 2009 7:22pm |
Hmmmm, wounder would it be worth sticking the standard wheels back on for the trip to the dealers. |
Mon Aug 17 2009 8:26pm |
When did you notice the problem with access mode?
Mon Aug 17 2009 8:43pm |
hi,
Mon Aug 17 2009 8:51pm |
I'd be tempted to put the 20's back on then, if it's intermittent it may have generated fault codes that the dealer could call up.
Mon Aug 17 2009 9:10pm |
