![]() | Home > Technical > P0170 code help! ...2006 RRSSC... freeze data |
You get all that lot on the driver info screen................................................. |
CheM Member Since: 30 Jun 2009 Location: Los Angeles Posts: 9 ![]() |
i used a regular OBD II scanner i borrowed from a friend. It displays freeze data.... but i have no idea what it means lol |
You could try emailing BAS, one of the forum sponsors - BAS writes remaps for ECU's so that lot will probably mean something to him and he will be able to de-code it! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Is it P017000?
thanks i sent him an email =) |
i just saw p0170 but i assume its the same (fuel trim bank 1)... i cleaned the DTC and retested, same error. No other codes have popped up. |
software update seems to have fixed the problem. |
