Home > Technical > P0170 code help! ...2006 RRSSC... freeze data
CheM
My 2006 range rover sport S/C 4.2 starting giving me code p0170. This code comes on about 1minute after the car starts up (first i get a pending code, then after the second cycle i get the MIL). Car seems to run fine.
This is the freeze data i got:
ABSLT TPS% ....21.9
ENG RPM ..........650
BARO RPS KPA ....101
calc load %.........37.6
MAF Flow GR/SE...8.26
MAP KPA..............46
outside temp.....71
Coolant....136
IAT F.............91
IGN Advance DE ....5.5
ST FTRM1%........ 15.6
LT FTRM1%........ 0.7
ST FTRM2%........ 12.5
LT FTRM2%........ 0.0
ST FTRM3%........-100.6
LT FTRM3%........-100.6
ST FTRM4%........-100.6
LT FTRM4%........-100.6
VEH Speed MPH...... 4
ABSLT Load % 3.0
FUEL PRESS KPAG....291
FUEL SYS 1..............closed
FUEL SYS 2..............closed
REL TPS % .............. 5.8
THROT CMD%..... ..... 11.7
ABS TPS B% ............ 56.8
ACC POS D%.................14.1
ACC POS E%............... 14.1
EVAP PURGE %.........30.1
CMD ED Ratio.......... 0.969
FUEL LEVEL %........ 13.7
VPWR V............ 14.121
ENG RUN M:S.... 2:28
Post #232662 Wed Aug 05 2009 8:08am
Tim in Scotland
You get all that lot on the driver info screen................................................. Question Shocked
LR must be putting one huge screen in the binnacle of USA spec cars to get all that info on display.
There is something you are not telling us - like you have a means of accessing/downloading the Engine ECU fault log 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #232671 Wed Aug 05 2009 9:29am
CheM
i used a regular OBD II scanner i borrowed from a friend. It displays freeze data.... but i have no idea what it means lol
Post #232691 Wed Aug 05 2009 3:48pm
Tim in Scotland
You could try emailing BAS, one of the forum sponsors - BAS writes remaps for ECU's so that lot will probably mean something to him and he will be able to de-code it! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #232693 Wed Aug 05 2009 3:59pm
Bobby
Is it P017000?
P017000 Fuel Trim (Bank 1)
• Fuel adaption Bank 1 exceeds threshold
Check for other DTCs and rectify as necessary.
Clear DTC and retest. Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #232699 Wed Aug 05 2009 11:22pm
CheM
thanks i sent him an email =)
Post #232701 Wed Aug 05 2009 11:40pm
CheM
Bobby wrote:
Is it P017000?
i just saw p0170 but i assume its the same (fuel trim bank 1)...
i cleaned the DTC and retested, same error. No other codes have popped up.
Post #232702 Wed Aug 05 2009 11:41pm
CheM
CheM wrote:
Bobby wrote:
Is it P017000?
software update seems to have fixed the problem.
Post #233153 Mon Aug 10 2009 5:58pm
Bobby
Thumbs Up Malaysia Boleh!
Post #233192 Mon Aug 10 2009 10:06pm
