Home > Off Roading & Green Laning > sasquatch offroad adjustable sensor rods INSTALLED!
phil.
United States 2006 Range Rover Sport 4.4 V8 HSE Java Black
finally got them put on over the weekend. i shortened the rods about 10mm which should equate to a 1.5" to 2" lift. sorry for the crappy camera pics. these ones in the garage are to show immediately before and after, with the slight difference being the front wheel turned a bit. if you look real close at the clearance on the rear wheels, you can notice the difference. i won't bother posting the comparison pics at each height, but you can check out the full set on Flickr. and now the pics, click thru for the fullsize pics.
stock offroad height
sasquatch offroad height
here's an old pic i dug up after i got my nittos
here's a similar pic with the new offroad height
Post #232556 Tue Aug 04 2009 12:23am
MAW
Is it normal to have a garage that tidy Confused Laughing
Post #232561 Tue Aug 04 2009 6:47am
phil.
LOL. about a month ago i finally got around to painting over the drywall so it forced me to clean up in the process
Post #232629 Tue Aug 04 2009 5:22pm
Leo
Kenya
Post #232636 Tue Aug 04 2009 7:34pm
lespes
Guernsey 2006 Range Rover Sport TDV6 HSE Buckingham Blue
Is this an easy mod? did you make new rods?
Suppose the on road hieght is effectivley the old off road height
what the heck happens when you hit something underneath with the extra 1 - 2 inch lift, does it go into super super extended mode
Post #232648 Tue Aug 04 2009 10:45pm
phil.
yes this is an extremely easy mod. all it takes is a flat head screwdriver to help you pop off the existing rods and these just slide right on in its place. these rods are from sasquatch off road. LRL Mag did a write up on it.
http://lrlmag.com/_blog/The_Land_Rover_Blo...3_a_lift!/
same exact rods for our vehicles. yes, my current normal height is roughly equivalent to the standard offroad height.
Post #232669 Wed Aug 05 2009 8:55am
jess
2006 Range Rover Sport TDV6 HSE Giverney Green
hi, can they be used to lower the ride hight to?
Post #232696 Wed Aug 05 2009 8:16pm
lespes
cheers Very Happy
Post #232697 Wed Aug 05 2009 9:47pm
cplatt
United States 2008 Range Rover Sport Supercharged Java Black
That's awesome, where do you get the new rods? I gotta have 'em! Do you have a contact number or email address for them? The LRL link has gone bad. Any long term effects from running them?
Thanks!
Charlie
Post #256050 Wed Feb 17 2010 3:35pm
cplatt
Nevermind, found them on another post. Ordered them and can't wait to get them on. Thanks!!!
Post #256054 Wed Feb 17 2010 3:49pm
phil.
if you keep the rods on full time, you'll want to get a 4 wheel alignment.
on a side note, i'm needing to replace my nittos soon and seriously considering going to the goodyear dura tracs in 275/65-18. any thoughts on if the spare will fit underneath?
Post #256081 Wed Feb 17 2010 7:35pm
diamond
Greece 2009 Range Rover Sport TDV6 SE Alaska White
what about the ride quality on the new standard height. Isn't more bumpy because air suspension is working like being in offroad mode? 2009 Range Rover Sport 2.7 TDV6 SE, Alaska White, Almond leather, tinted windows, active rear diff, tow pack, HiICE, full spare: gone and already missed
2004 Fiat Panda 1.2 Climbing 4x4
http://www.youtube.com/watch?v=fAg4DdXAp7Y
Post #256115 Wed Feb 17 2010 10:00pm
phil.
i didn't really notice a difference in ride quality. i wouldn't think it'd be more bumpy b/c it's not like i'm down in access height and right on the verge of the bump stops. i can definitely notice the height difference and it's effect on handling.
Post #256152 Thu Feb 18 2010 12:30am
