Home > Off Roading & Green Laning > sasquatch offroad adjustable sensor rods INSTALLED! |
phil. Member Since: 29 May 2006 Location: California Posts: 13 |
finally got them put on over the weekend. i shortened the rods about 10mm which should equate to a 1.5" to 2" lift. sorry for the crappy camera pics. these ones in the garage are to show immediately before and after, with the slight difference being the front wheel turned a bit. if you look real close at the clearance on the rear wheels, you can notice the difference. i won't bother posting the comparison pics at each height, but you can check out the full set on Flickr. and now the pics, click thru for the fullsize pics.
Tue Aug 04 2009 12:23am |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 |
Is it normal to have a garage that tidy |
Tue Aug 04 2009 6:47am |
Leo Member Since: 17 Sep 2007 Location: Nomad Posts: 554 |
Tue Aug 04 2009 7:34pm |
lespes Member Since: 16 Jun 2008 Location: Channel Islands Posts: 1052 |
Is this an easy mod? did you make new rods?
Tue Aug 04 2009 10:45pm |
yes this is an extremely easy mod. all it takes is a flat head screwdriver to help you pop off the existing rods and these just slide right on in its place. these rods are from sasquatch off road. LRL Mag did a write up on it.
Wed Aug 05 2009 8:55am |
jess Member Since: 19 Jul 2009 Location: england Posts: 17 |
hi, can they be used to lower the ride hight to? |
Wed Aug 05 2009 8:16pm |
cheers |
Wed Aug 05 2009 9:47pm |
cplatt Member Since: 17 Feb 2010 Location: Alexandria, VA Posts: 13 |
That's awesome, where do you get the new rods? I gotta have 'em! Do you have a contact number or email address for them? The LRL link has gone bad. Any long term effects from running them?
Wed Feb 17 2010 3:35pm |
Nevermind, found them on another post. Ordered them and can't wait to get them on. Thanks!!! |
Wed Feb 17 2010 3:49pm |
if you keep the rods on full time, you'll want to get a 4 wheel alignment.
Wed Feb 17 2010 7:35pm |
diamond Member Since: 09 Feb 2009 Location: Dusseldorf, Germany Posts: 217 |
what about the ride quality on the new standard height. Isn't more bumpy because air suspension is working like being in offroad mode? 2009 Range Rover Sport 2.7 TDV6 SE, Alaska White, Almond leather, tinted windows, active rear diff, tow pack, HiICE, full spare: gone and already missed
Wed Feb 17 2010 10:00pm |
i didn't really notice a difference in ride quality. i wouldn't think it'd be more bumpy b/c it's not like i'm down in access height and right on the verge of the bump stops. i can definitely notice the height difference and it's effect on handling. |
Thu Feb 18 2010 12:30am |
