Home > Maintenance & Modifications > put petrol in by mistake
ViewWise
hoppy_70 wrote:
£4k to fix Shocked That seems a bit steep. I was a diesel fitter when I first left school and we used to put a gallon of petrol in with the diesel to stop it freezing up in winter (it used to be cold in winter before global warming!). This never did the vehicles any harm and even though modern cars are more electrically sensitive it's still the same fuel systems.
I did this on an audi a4 TDI, filled it to the brim with petrol. Just drained it off and refilled with diesel. I even used (and am still using 2 years later) the 'dirty' fuel in my lawn mower. Smokes a bit on start up but fine once running.
I don't understand why the fuel pump would need to be replaced? Is this, just in case it breaks at some stage because it's had petrol in??? Tosh.
If it were me i'd have drained and refilled to see what happened.
Incidentally, this is much worse to do the other way round (diesel into a petrol). Censored the cats i believe (so to speak).
£4k is mad Shocked Shocked
Its normal land rover price to perform all of this...
1 . Referring to the relevant section in the workshop manual, drain the fuel tank.
2 . Remove the fuel tank assembly.
3 . Remove pump/sender module and invert to drain excess fuel.
4 . Remove all traces of residual fuel within the tank using clean absorbent cloth/paper.
5 . Clean and flush all low pressure pipes.
6 . Renew the fuel filter.
7 . Renew the high pressure fuel pump.
8 . Renew all high pressure fuel pipes.
9 . Renew the diverter pipe and both fuel rails.
10 . Renew all six fuel injectors
11 . Reassemble pump/sender module to fuel tank and install to vehicle
12 . The tank must be filled with clean diesel fuel
13 . Road test vehicle for at least ten miles, checking for normal engine operation and no stored diagnostic trouble codes are logged.
14 . Return vehicle to customer. WINNER - 2008 Best All New Photograph
WINNER - 2009 Best All New Photograph
Post #226903 Thu May 28 2009 10:24am
will_wonka
Location: Tminus 12 months for the RS Sport Supercharged!!
Shocked Shocked
Blimey L322 Big Daddy SUPERCHARGED 5.0 Autobiography - Here & Now!
5 series for the miles Smile
RRS S/C factory built HST - Gone
45 others have been and gone!
Post #226905 Thu May 28 2009 10:49am
leedsunited
United Kingdom 2008 Range Rover Sport TDV6 HSE Java Black
bex wrote:
Adding petrol to a diesel engined Kia makes it burn better in the scrap dealers Rolling with laughter
I wish Land Rover offered a seven year unlimited mileage warranty!!!!!!
Post #226920 Thu May 28 2009 12:26pm
gus4073
Its a nightmare, i did the same thing to my Golf, managed to drive it home with it starting to pink a bit, realised the problem, drained out the petrol refulled with diesel, and the car was fine, i have since covered 30000 more miles since doing it and have had no problems.
Top gear did a feature on it some time back, where they fuelled a petrol car with diesel and vice versa, they ran both cars through a full tank of fuel, all be it a little perfomance effecting, but neither car suffered any ill effects.
I think it is a bit of a garage scam..... the new fuel pump is just ridiculas.
Drain the fuel, refill with Diesel if it runs ok then its happy days, if not you have only lost the price of a bit of diesel. Very Happy
Post #226972 Fri May 29 2009 7:35am
hoppy_70
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Rimini Red
I have no idea how Land Rover justify all that work! Are you sure you told them petrol and not "sulphuric acid" by mistake???
A) what possible damage could petrol do to the pipes? Petrol will mix in with diesel as soon as it's ran through the pipes and clear in moments.
B) How do landrovers manage in countrys where the fuel quality is Censored and mixed with allsorts of other flammables? Are they saying it should cost you 4k at every fill. Rubbish.
They justify these "precautionary" measures by saying this could cause x,y and z. It never does but because it did once they justify having your pants down.
If these are land rovers recommendations then they should be wearing a mask. Rolling Eyes Range Rover Sport HSE DYnamic SDV6 Velocity blue 2020 MY
Range Rover sport HSE Dynamic P400e Silver
Range Rover Sport 3.0 SDV6 HSE Dynamic 2016 MY
Range Rover sport 3.6tdv8HSE 2007 Gone
Range Rover sport 2.7tdv6SE 2005 Gone
Range Rover sport 2.7tdv6SE 2007 honey
Range rover Vogue 2005 4.4 - GONE and missed
BMW 535d M sport 2006 - GONE not as missed
BMW X5 4.4 2004 sport - GONE
Post #226978 Fri May 29 2009 8:05am
lespes
Guernsey 2006 Range Rover Sport TDV6 HSE Buckingham Blue
Get the feeling many people see a RRS and think "Loads of Money" which leads them to take the p++S or approach you as a registered charity!
Post #227005 Fri May 29 2009 4:36pm
leedsunited
My mate did this with his Audi A4, RAC recovered him to Audi dealer, they drained the petrol bled all the other pipes filled it with deisel and of he went, £200 if i remeber correctly.
RR Dealer "even Dick Turpin wore a mask"
Post #227386 Fri Jun 05 2009 3:13pm
