Home > Maintenance & Modifications > put petrol in by mistake |
ViewWise Member Since: 13 Mar 2008 Location: London Posts: 704 |
Its normal land rover price to perform all of this... 1 . Referring to the relevant section in the workshop manual, drain the fuel tank. 2 . Remove the fuel tank assembly. 3 . Remove pump/sender module and invert to drain excess fuel. 4 . Remove all traces of residual fuel within the tank using clean absorbent cloth/paper. 5 . Clean and flush all low pressure pipes. 6 . Renew the fuel filter. 7 . Renew the high pressure fuel pump. 8 . Renew all high pressure fuel pipes. 9 . Renew the diverter pipe and both fuel rails. 10 . Renew all six fuel injectors 11 . Reassemble pump/sender module to fuel tank and install to vehicle 12 . The tank must be filled with clean diesel fuel 13 . Road test vehicle for at least ten miles, checking for normal engine operation and no stored diagnostic trouble codes are logged. 14 . Return vehicle to customer. WINNER - 2008 Best All New Photograph WINNER - 2009 Best All New Photograph |
Thu May 28 2009 11:24am |
leedsunited Member Since: 04 Aug 2008 Location: Selby Posts: 1368 |
I wish Land Rover offered a seven year unlimited mileage warranty!!!!!! |
Thu May 28 2009 1:26pm |
gus4073 Member Since: 26 May 2009 Location: coventry Posts: 11 |
Its a nightmare, i did the same thing to my Golf, managed to drive it home with it starting to pink a bit, realised the problem, drained out the petrol refulled with diesel, and the car was fine, i have since covered 30000 more miles since doing it and have had no problems.
Fri May 29 2009 8:35am |
hoppy_70 Member Since: 28 Mar 2009 Location: United Kingdom Posts: 437 |
I have no idea how Land Rover justify all that work! Are you sure you told them petrol and not "sulphuric acid" by mistake???
Fri May 29 2009 9:05am |
lespes Member Since: 16 Jun 2008 Location: Channel Islands Posts: 1052 |
Get the feeling many people see a RRS and think "Loads of Money" which leads them to take the p++S or approach you as a registered charity! |
Fri May 29 2009 5:36pm |
My mate did this with his Audi A4, RAC recovered him to Audi dealer, they drained the petrol bled all the other pipes filled it with deisel and of he went, £200 if i remeber correctly.
Fri Jun 05 2009 4:13pm |
