![]() | Home > Maintenance & Modifications > Upgraded Audio with Sat Nav, TV, HDD and Ipod |
gianluca Member Since: 18 Mar 2009 Location: Potenza Posts: 136 ![]() ![]() ![]() |
Thaks for the info!
Ok, gents, I have everything ready ..
Here I am again, with a little problem.
mobile fidelity Member Since: 21 May 2007 Location: NSW Posts: 12 ![]() ![]() |
You have OEM nav above the radio?
diamond Member Since: 09 Feb 2009 Location: Dusseldorf, Germany Posts: 217 ![]() ![]() ![]() |
This is exactly what a good forum means ![]() 2004 Fiat Panda 1.2 Climbing 4x4 http://www.youtube.com/watch?v=fAg4DdXAp7Y |
Thanks for your answer. Yes, I have the OEM navi in the main screen, with also all the infos on terrain response and compass. The guy doing the work says we need 10 meters of optic cable (5 from the dash to the boot and 5 in the opposite way...?? )to bring the OEM radio unit connected in the very back of the boot, on the roght hand side. He also says this should be 2.5 mm diameter . I have seen some of them on the bay; please have a look at object eBay Item No. 400029650291 . Do you thinks this will work? It is 5 mm wide, however.. ![]() ![]() |
ok this is how it works.
Ok, thanks.
So the only chance to have a better audio system is to keep the old one in the trunk and put a new one up front?
You got " i " button on the blinker stalk i.e. left side of steering wheel?
I suppose you mean the button that when pressed displays all the trip computer information on dash. Yes I have this one, although I can't see what's the relation with audio (except the stupid thing that clock is controlled by radio!!!) 2009 Range Rover Sport 2.7 TDV6 SE, Alaska White, Almond leather, tinted windows, active rear diff, tow pack, HiICE, full spare: gone and already missed
then remove the head unit from the car, make sure everything else is plugged back in and turn the ignition on and go through the display and see whats missing. |
Had the work done.
Here I am again with the pics of the changes.
