Home > General > Replacement stereo |
npinks Site Moderator Member Since: 26 Nov 2007 Location: Watching Posts: 6716 |
you would get a more functional (sat/TV/reversing camera etc) aftermarket satnav than the OEM (if they can be retro fitted) |
Wed Nov 26 2008 11:53am |
Welcome along Idris
Wed Nov 26 2008 12:09pm |
Idris Member Since: 26 Nov 2008 Location: London Posts: 3 |
Thanks Shmoogle and npinks
Wed Nov 26 2008 4:06pm |
It'll be interesting to see how it pans out - sounds like you know what you're doing
Thu Nov 27 2008 12:20pm |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 |
Welcome ! - I thought the amps were under the drivers seat? |
Thu Nov 27 2008 1:13pm |
I haven't had a chance to have a look yet but from what I hear it's the same as the Vogue or the X5 and everything is in the boot. You may be right and they could be under the seat. Will let you know what I find and where. Idris |
Thu Nov 27 2008 6:30pm |
Murdered out Member Since: 08 Feb 2008 Location: Arizona Posts: 324 |
the BEST thing to do is get the RRS sat/nav radio. You truely need the oem radio. The radio is linked to the alarm system and many other componets, without the an oem radio the CAN-bus system or equiv is not properly working. The amp is under the seat on the right hand side.
Thu Nov 27 2008 11:25pm |
if you did not have your main Audi head unit in, it would take out the entire MOST Bus. Thats the fibre optic bus that interconnects absolutely all the infotainment stuff. you would have no Audio Amplifier, Sat Nav, Telephone, TV, LCD display Etc Etc. It cannot be by passed as the Integrated Head Unit as it is called, acts as the gateway between the MOST and the CAN, it also provides all the security communications and validation for the rest of the systems. |
Fri Nov 28 2008 6:18pm |
Like i said.... under the drivers seats - on normal cars |
Sat Nov 29 2008 9:16am |
gianluca Member Since: 18 Mar 2009 Location: Potenza Posts: 136 |
Hallo folks, I have just registered to this interesting forum.
Wed Mar 18 2009 11:52am |
FAT_RRS Member Since: 18 Jun 2008 Location: COLORADO Posts: 98 |
You have to keep the OEM radio in the car. Period
Wed Mar 18 2009 5:39pm |
Thanks for your answer. Does it mean that I can connect the new unit in the front dash and keep the OEM unit connected somewhere else in the car, eg hidden? Is it technically feasible? Is it needed to let all the infos system of the car work? |
Wed Mar 18 2009 6:21pm |
Yes, the head unit is a vital piece of kit. You have keep it "in circuit" as it were. Not sure whether the wiring looms would let you move it somewhere else so you could fit your Kenwood head unit in
Thu Mar 19 2009 9:17am |
2nd Rower Member Since: 12 Nov 2007 Location: Upside Down Posts: 1382 |
stephenw previously replaced his head unit and kept the orignal hidden in the rear:
Thu Mar 19 2009 9:47pm |
