![]() | Home > General > Replacement stereo |
npinks Site Moderator Member Since: 26 Nov 2007 Location: Watching Posts: 6716 ![]() ![]() |
you would get a more functional (sat/TV/reversing camera etc) aftermarket satnav than the OEM (if they can be retro fitted) |
Welcome along Idris |
Idris Member Since: 26 Nov 2008 Location: London Posts: 3 ![]() ![]() |
Thanks Shmoogle and npinks
It'll be interesting to see how it pans out - sounds like you know what you're doing |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 ![]() ![]() ![]() |
Welcome ! - I thought the amps were under the drivers seat? |
I haven't had a chance to have a look yet but from what I hear it's the same as the Vogue or the X5 and everything is in the boot. You may be right and they could be under the seat. Will let you know what I find and where. Idris |
Murdered out Member Since: 08 Feb 2008 Location: Arizona Posts: 324 ![]() ![]() ![]() |
the BEST thing to do is get the RRS sat/nav radio. You truely need the oem radio. The radio is linked to the alarm system and many other componets, without the an oem radio the CAN-bus system or equiv is not properly working. The amp is under the seat on the right hand side.
if you did not have your main Audi head unit in, it would take out the entire MOST Bus. Thats the fibre optic bus that interconnects absolutely all the infotainment stuff. you would have no Audio Amplifier, Sat Nav, Telephone, TV, LCD display Etc Etc. It cannot be by passed as the Integrated Head Unit as it is called, acts as the gateway between the MOST and the CAN, it also provides all the security communications and validation for the rest of the systems. |
Like i said.... under the drivers seats - on normal cars ![]() |
gianluca Member Since: 18 Mar 2009 Location: Potenza Posts: 136 ![]() ![]() ![]() |
Hallo folks, I have just registered to this interesting forum.
FAT_RRS Member Since: 18 Jun 2008 Location: COLORADO Posts: 98 ![]() ![]() ![]() |
You have to keep the OEM radio in the car. Period
Thanks for your answer. Does it mean that I can connect the new unit in the front dash and keep the OEM unit connected somewhere else in the car, eg hidden? Is it technically feasible? Is it needed to let all the infos system of the car work? |
Yes, the head unit is a vital piece of kit. You have keep it "in circuit" as it were. Not sure whether the wiring looms would let you move it somewhere else so you could fit your Kenwood head unit in |
2nd Rower Member Since: 12 Nov 2007 Location: Upside Down Posts: 1382 ![]() ![]() ![]() |
stephenw previously replaced his head unit and kept the orignal hidden in the rear:
