Home > General > Towing Electric Pack |
Theo_Pental Member Since: 10 Aug 2008 Location: Notts Posts: 113 |
Has anybody recently bought the towing electric pack for the RRS recently please?
Fri Mar 13 2009 12:12pm |
Will this do you Theo?
Fri Mar 13 2009 12:35pm |
monkey9952 Member Since: 09 May 2007 Location: In A mess Posts: 163 |
Got Tow Bar & Electrics from Ebay , see a couple of dealers offering electrics so just need to keep an eye out or follow shmoogles link |
Fri Mar 13 2009 3:25pm |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 |
How long is backorder? the LR kit is to fit ..... |
Fri Mar 13 2009 6:07pm |
Gary Member Since: 22 Jun 2006 Location: Essex Posts: 268 |
I paid about 375 last September fitted, and well worth it as I don't think this is an easy DIY fit (see links on this forum)
Fri Mar 13 2009 6:53pm |
Sorry forgot to mention that this was an indepentant fit, not main dealer so provided the loom is from LR there should be no probs? |
Fri Mar 13 2009 6:55pm |
It is an easy DIY job - about an hour - parts £75 from memory! I fitted mine to the first RRS - took them off and fitted to the current RRS |
MAW, what was involved as I have heard horror stories from other forum members? |
Fri Mar 13 2009 6:57pm |
Not a biggie , You need to take out some trim in the boot / Remove light / Take out a loom and replace with the loom in the kit , which just plugs into your existing connectors. Dropping the spare tyre will give room to feed cable through etc . . Didnt find it difficult just need to follow the Instructions and all is ok. |
Fri Mar 13 2009 8:00pm |
Per Monkey says - doddle - instructions very clear. Once you have access - you pull a section of loom and replace with the Tow electrics loom - what stories have you heard and i can comment - really is easy to do - biggest hurdle was persuading the light cluster out w/o damging paint or the unit but really nothing to it... |
Sat Mar 14 2009 8:28am |
