Home > General > squeaky wipers
Frozen of Wiltshire
United Kingdom 2007 Range Rover Sport TDV8 HSE Buckingham Blue
squeaky wipers
Do your rain sensing wipers squeak a lot when they start after light drizzle? Happens to mine quite a bit - usually when a car passes heading the opposite way and covers my windscreen with light spray. Wipers detect it and Squeeeeeeeaaaaakkkkk across the screen. I reach for the water button, give it a squirt or two and problem solved. Gets a bit tiresome after the dozenth time or so though... Rolling Eyes
On my last car (porsche) when you pressed the flick wipe, it sensibly gave one squirt of window washers first, then did the flick wipe. No squeak. Does anyone know if the RRS can be configured to do the same - washer squirt before starting wipers after an idle period or flick wipe? Or does anyone have a better solution?
thanks Range Rover Sport TDV8 HSE, Buckingham Blue with Ebony Black
Defender 90 TD5, Tonga Green
Post #214933 Wed Mar 04 2009 9:18am
Misery
Give the arms a quick bend that will do the trick. Thumbs Up Thumbs Up
Post #214934 Wed Mar 04 2009 9:20am
Frozen of Wiltshire
don't follow you - bend how/which way? Range Rover Sport TDV8 HSE, Buckingham Blue with Ebony Black
Post #214937 Wed Mar 04 2009 9:25am
Zilch
Australia 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
not a quote to leave out there on this forum i can assure you Laughing Another Pommie Bar Steward down under
MY20 Defender 110 SE P400 Eiger/Ebony
MY10 3.0 RRS TDv6 Fuji/Ebony/Anigre
Post #214947 Wed Mar 04 2009 9:36am
will_wonka
Location: Tminus 12 months for the RS Sport Supercharged!!
Rolling with laughter Rolling with laughter
He bends both ways........allegedly Whistle Whistle Whistle L322 Big Daddy SUPERCHARGED 5.0 Autobiography - Here & Now!
5 series for the miles Smile
RRS S/C factory built HST - Gone
45 others have been and gone!
Post #214980 Wed Mar 04 2009 10:05am
Frozen of Wiltshire
Embarassed ....too late to edit already... better choice of words required next time - p.s. it's hard to bend when you're frozen... Laughing Range Rover Sport TDV8 HSE, Buckingham Blue with Ebony Black
Post #214993 Wed Mar 04 2009 11:02am
Money Money Money
2005 Range Rover Sport Supercharged Java Black
Re: squeaky wipers
thanks
I'm with you mate, mine make an awful racket, ALSO my intermitent setting will only go as slow as about 3seconds, I try using the other setting on the stalk to change the waiting time but doesn't seem to work!
Do the RRS S/C have automatic wipers?
Is this a stealer problem?
Post #214995 Wed Mar 04 2009 11:14am
There were LOTS of complaints about the original sets of wipers that went on the cars. MMM, I notice yours is a 2005 model - if you've not changed them since then, LR now supply wipers made from a slightly different compound and are much quieter. Alternatively, there are RainX wipers that folks have also fitted with success.
A search of this forum for noisy wipers will give you the history Thumbs Up
Post #214997 Wed Mar 04 2009 11:18am
Frozen of Wiltshire
found the old threads now - just spent ages going through them and sounds like the best solution was the new improved LR wiper blades part number DKC500150 - so I'll try those when it goes in for service in a few months and put up with it until then.
Post #215010 Wed Mar 04 2009 11:57am
Pleasure Thumbs Up
Post #215011 Wed Mar 04 2009 11:58am
Misery
Frozen of Wiltshire Believe me I don't mind which way you bend. Wink Wink
Seriously I have had two sets of wipers the new code number ones as well, both squeaked after a while. My car has just come out of the workshops after some warranty work, I mentioned the squeak to the service manager his reply no worries a little bend and they will be fine.
THEY ARE NOW. Bow down Bow down Bow down
The bend the arm slightly I think.
Post #215053 Wed Mar 04 2009 2:19pm
Away from the screen or towards? Away I presume? Confused
Post #215059 Wed Mar 04 2009 2:46pm
Frozen of Wiltshire
ok, read something about that too. The angle the rubber hits the glass causes the squeaking and apparently twisting the blade to adjust that sorts it. Sounds like something I will delegate as part of the service before I snap off the wipers trying it.
thanks for the advice all Range Rover Sport TDV8 HSE, Buckingham Blue with Ebony Black
Post #215102 Wed Mar 04 2009 5:27pm
RichardC
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
had the same problem and changed them for Valeo XTRM wipers - you can find them on EBAY.
work perfectly now.
Post #215319 Thu Mar 05 2009 12:55pm
Must Fly
United Kingdom 2007 Range Rover Sport Supercharged Java Black
Windscreen Wipers - Aaargh!
Been having the same problem with windscreen wiper noise (squeaking badly) that a few other members have been having.
At first I thoroughly cleaned both the windscreen AND the wipers - there was an immediate improvement but not for long.
I just bought some 22" RAIN-X wipers. The drivers side fits perfectly - but for some reason (probably finger trouble on my behalf) the passenger side don't!
Only about two-thirds of the blade touches the screen - the other third just sticks up!
Could somebody please tell me what I might be doing wrong? !!
Sorry to be so dim!
BTW - it's a 2007 RRS S/charged.
Thanks alot
M
Post #258426 Sat Mar 06 2010 9:42pm
