![]() | Home > General > squeaky wipers |
Misery Member Since: 07 Dec 2005 Location: Waiting for L405 Posts: 2555 ![]() ![]() |
Give the arms a quick bend that will do the trick. |
Frozen of Wiltshire Member Since: 08 Jan 2009 Location: Wiltshire Posts: 66 ![]() ![]() ![]() |
don't follow you - bend how/which way? Range Rover Sport TDV8 HSE, Buckingham Blue with Ebony Black
Zilch Member Since: 20 Mar 2006 Location: Sydney, sometimes the Whitsundays Posts: 2835 ![]() ![]() ![]() |
not a quote to leave out there on this forum i can assure you ![]() MY20 Defender 110 SE P400 Eiger/Ebony MY10 3.0 RRS TDv6 Fuji/Ebony/Anigre |
![]() ![]() He bends both ways........allegedly ![]() ![]() ![]() 5 series for the miles ![]() RRS S/C factory built HST - Gone 45 others have been and gone! |
Money Money Money Member Since: 09 Feb 2009 Location: England Posts: 32 ![]() ![]() |
I'm with you mate, mine make an awful racket, ALSO my intermitent setting will only go as slow as about 3seconds, I try using the other setting on the stalk to change the waiting time but doesn't seem to work! Do the RRS S/C have automatic wipers? Is this a stealer problem? Cheers |
There were LOTS of complaints about the original sets of wipers that went on the cars. MMM, I notice yours is a 2005 model - if you've not changed them since then, LR now supply wipers made from a slightly different compound and are much quieter. Alternatively, there are RainX wipers that folks have also fitted with success.
found the old threads now - just spent ages going through them and sounds like the best solution was the new improved LR wiper blades part number DKC500150 - so I'll try those when it goes in for service in a few months and put up with it until then.
Pleasure |
Frozen of Wiltshire Believe me I don't mind which way you bend. |
Away from the screen or towards? Away I presume? |
ok, read something about that too. The angle the rubber hits the glass causes the squeaking and apparently twisting the blade to adjust that sorts it. Sounds like something I will delegate as part of the service before I snap off the wipers trying it.
RichardC Member Since: 17 Nov 2008 Location: London Posts: 6 ![]() ![]() ![]() |
had the same problem and changed them for Valeo XTRM wipers - you can find them on EBAY.
Must Fly Member Since: 16 Apr 2009 Location: All over the world Posts: 13 ![]() ![]() ![]() |
Been having the same problem with windscreen wiper noise (squeaking badly) that a few other members have been having.
