Home > Technical > Lazy entry |
umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944 |
You mean it still moves back when you remove the key from the ignition, along with the steering column? If so, that's not Lazy Entry, that's an easy exit "feature" built into cars equipped with electric steering columns, not sure if they gave it a name... The knob to adjust the steering column should have an Auto and an "Off/Manual" (a steering wheel icon) position: If the knob is presently on Auto, flip it to the other position and the seat and steering columns should stop moving automatically when you remove the key. |
Mon Feb 23 2009 11:04pm |
Yes, if your problem is like what umbertob suspects, this is called "automatic seat movement". Like umbertob advises, to prevent automatic movement of the driver’s seat, turn the control to its clockwise position. Malaysia Boleh!
Tue Feb 24 2009 12:39am |
C10KO Member Since: 04 Jan 2009 Location: . . . searching . . . Posts: 1136 |
Thanks guys, will give it go right away.
Tue Feb 24 2009 6:55am |
Coko, you're incorrigble! RTFM!!
Tue Feb 24 2009 7:10am |
Tue Feb 24 2009 7:45am |
