Home > Technical > Park brake fault |
muffd Member Since: 20 Jun 2007 Location: Glasgow, Scotland OR Cumbre del Sol, Spain Posts: 325 |
when the fault appeared, was the parking brake locked on (i.e. the car was stuck and wouldn't move until it reset?)
Sun Feb 22 2009 11:31am |
ste777 Member Since: 16 Feb 2009 Location: United Kingdom Posts: 5 |
Hi Graham , yes the brake was locked on until I restarted the car. Tried pulling off with the fault on, which should release the brake but it wouldn`t release. Have you had the same problem ? ste777 |
Sun Feb 22 2009 3:56pm |
this happened to me once. And boy was it a serious inconvenience. I drove to rural Northern Ireland (from Glasgow), parked in a hotel car park, put the hand brake on and heard a 'farting' noise. I then had the same problem you had. Damn car wouldn't move forward or back so I locked her up, went for lunch and when I came back, the handbrake disengaged (thank goodness as I was miles from anywhere). I did not use the handbrake for a week until I got home and I then went to the Land Rover dealer. They allegedly replaced the hand brake shoes and assembly under warranty and I have had no trouble since. I have since found out that the dealer explanation for this is bullshit - as the handbrake apparently does not have brake shoes. But I might be wrong in this.
Sun Feb 22 2009 11:01pm |
A weak battery can cause this problem.
Sun Feb 22 2009 11:31pm |
Got the car back on the 19th feb , they said that they traced the fault to the steering column adjuster (i`ve got this disabled because I have got hand controls fitted due to me being a paraplegic). They said that when the car computer booted up after being in sleep mode it was detecting that the steering column had a fault because it was disabled and this showed up as a park brake fault (I don`t know why either). They enabled the column adjuster and hid it inside the cowling under the column , this left a big hole in the cowling where the adjuster used to be but I wasn`t bothered because they said that the problem was now gone. ALAS! this was not the truth because two days after I picked it up the fault occured again and has done so each day since. Phoned them up today and they said they had contacted Land Rover when they had my car in for some advice about the problem and they have only just got back to them. They recomend that they replace the "park brake computer". So now I`m waiting for LR to get back to me to let me know when they can get me a replacement vehicle whilst they "repair" mine (we`ll see). I`ll post again with an update when they`ve done it , so bye for now. ste777 |
Wed Feb 25 2009 11:33am |
