Home > Technical > Hardwire GPS Speed Detector
Richchad
Well just bought the new Talex GPS Speed Detector ( http://www.talex.co.uk/ ) and I want to hardwire it.
I actually bought it in Halfords for £58.71, over half the website price and 3 year subscription only £59.
It seems to locate best on top right front corner of the dash without any fixings, so wanted to run the wire down the side, thought of connecting to the footwell light but cannot see if there is a permanent 12 volts there.
BTW the detector seems to work okay, picked up all fixed and possible mobile detector sites that I passed okay.
Not sure whether to buy the add on Laser detector ( http://www.talex.co.uk/LaserDetector ) as it supposedly at half price. The Website blurb is all a bit naff.. Laughing Arrived - RRSport 2016 HSE SDV6 HSE
Loire Blue/Ivory leather Privacy Glass
Gone - RRSPORT 2010 TDV6 HSE
Stornaway/Ebony Premium leather with Lunar stitching, Heated Steering Wheel and Privacy Glass.
Gone - RRSPORT TDV6 HSE
Buckingham Blue/Ivory, Privacy Glass, Tasmods Sills, Supercharged Black Badges all round, Grille & Vents, plus RRSport Sticker & Brolly of course.
Post #211926 Mon Feb 16 2009 3:30pm
I just got a Roadpilot microGo from Halfords, it is powered by a mini usb lead with a cig light attachment
Looked at running it via a long mini usb lead (same lead to use it to connect to my PC), connected to a cig lighter converter, that showed the correct output as on the actual OEM lead.
As soon as i switched the ignition on the MicroGo started to buzz like it was going to blow up Shocked
I now decided to buy a cig lighter extension, splice that in instead of plugging it in and use the actual OEM lead to power it so i don't blown it or my self up
Post #211931 Mon Feb 16 2009 4:16pm
Richchad
Does the microGo display the actual speed limit of the road you are on all the time, the Talex doesn't I have since found out, only when in camera detection areas, maybe I ought to change mine, where and how have you fixed it to the dash, have you tested it yet for detection? Arrived - RRSport 2016 HSE SDV6 HSE
Post #211935 Mon Feb 16 2009 4:26pm
The mircoGo displays your speed as a default setting, then when approaching a camera it starts to beep if your going too fast, displaying your current speed, the actual speed limit in a circle and a decreasing bar, showing how far from the camera you are
Also changes the distance when on motorways to take into account for the extra speed.
All in all, for what it does, I am very happy with it, the power lead is a little bit short for my FL2, (section between the seats is alot lower in mine), but in the RRS TDV8 i had last week on loan, the lead was a perfect length and the warnings were very welcome Whistle
Post #211949 Mon Feb 16 2009 5:07pm
Richchad
So, like the Talex unit it doesn't display the speed limit until you are in a detection zone, hmm maybe I will keep the Talex after all, although the MicroGo does have a neat looking display.
Just need to find out where to connect to a 12 volt supply around the dash area as the cigarette lighter adapter looks so messy, need an auxiliary socket in the front dash area somewhere. Rolling Eyes Arrived - RRSport 2016 HSE SDV6 HSE
Post #211956 Mon Feb 16 2009 5:18pm
lemm
2005 Range Rover Sport Supercharged Vesuvius Orange
re: location of power... i cheated and pulled a switched live through from my NAV.TV unit. Connected this up a new cigarette lighter and hid it behind the panel holding the light switch. Loads of space behind this panel, plus its then close to my final destination on bottom right hand corner of windscreen.. it's a fairly tight squeeze to pull the mini-usb through, but with a bit of perseverance you'll be fine.
ps. don't be scared to pull quite hard on the switch panel... a few of the metal clips might spring off but these will easily clip back in. RRS First Edition S/C, Vesuvius Orange, Rear Entertainment, Alpine TUE-T200DV, Stormer Alloys. (+ 19" MTR's for playing in the snow!)
Post #211964 Mon Feb 16 2009 5:35pm
Richchad
Thanks Lemm, so have I got this right, you found a switched live behind the light switch panel and connected a another cigarette lighter to it to plug in your Sat/Nav/TV unit? ...will take a look tomorrow...thanks for that. Thumbs Up Arrived - RRSport 2016 HSE SDV6 HSE
Post #211966 Mon Feb 16 2009 5:48pm
PJPR01
United States 2006 Range Rover Sport 4.4 V8 HSE Cairns Blue
http://www.rrsport.co.uk/forum/topic10937....r+detector
This should help you out...it's a sticky on how to hardwire a radar detector.
Very Happy PJPR
Cairns Blue HSE
180k Miles of Adventure
Post #211972 Mon Feb 16 2009 6:05pm
Richchad
PJPR01 wrote:
http://www.rrsport.co.uk/forum/topic10937.html?highlight=radar+detector
Very Happy
Thanks for that PJPR01, I found that one in my search but unfortunately it is to connect up to the centre light panel not the dash, thanks anyway... Wink Arrived - RRSport 2016 HSE SDV6 HSE
Post #211973 Mon Feb 16 2009 6:10pm
PJPR01
Oh...I see now. Hhmmm...let me check around again.
Very Happy PJPR
Cairns Blue HSE
Post #211975 Mon Feb 16 2009 6:15pm
but its given me a idea for the installation of mine in the FL2, cheers for that PJPR01
Post #211998 Mon Feb 16 2009 7:37pm
lemm
not quite... power for nav unit is pulled in from rear. A pain, but part of a second project to install a second battery. Easiest place to pull a new power feed in the front is from the existing cig lighter. RRS First Edition S/C, Vesuvius Orange, Rear Entertainment, Alpine TUE-T200DV, Stormer Alloys. (+ 19" MTR's for playing in the snow!)
Post #212010 Mon Feb 16 2009 10:05pm
