Home > General > air suspension slant when parked for 48 hours
rrsboy
2010 Range Rover Sport TDV8 HSE Santorini Black
hola..
see image - the rear passenger side suspension seems to 'sag' if the car is left parked for more than 48 hours. It only happens on that corner, or is certainly more pronounced. Is this indicative of a problem?
thanks, and apols for big pic
Post #210674 Mon Feb 09 2009 8:24pm
Tim in Scotland
Could be a sensor or you have a slight air leak in one of the suspension airbags - a visit to the dealer would be best before you damage something.
If you leave the car in access mode when you park up for that length of time does it raise back up to being level? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #210676 Mon Feb 09 2009 8:31pm
rrsboy
yes. after long enough e.g. 1 week parked up all of the suspension eventually lowers down. When i get in and start the engine, it all reinflates. i just assumed this was normal?
Post #210677 Mon Feb 09 2009 8:37pm
mr_moped
United Kingdom 2006 Range Rover Sport TDV6 HSE Zambezi Silver
You need your air suspension calibrating! Mine had exactly the same problem and was sorted out by the dealer at the beginning of Jan.
Post #210679 Mon Feb 09 2009 9:39pm
Bobby
or it could be as simple as this...
http://www.rrsport.co.uk/gallery/albums/us...arked1.pdf Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #210697 Tue Feb 10 2009 12:23am
I remember Jay Mann's doing that. PM him and ask what the issue was....or wait 5 mins and he'll no doubt log on for the day! Laughing Runner up - 2009 Best Avatar Award Sad
Post #210703 Tue Feb 10 2009 7:05am
Josh
If I'm reading this correctly....you are leaving your car parked up for a week in standard road height. So not locked in access height.
If that is the case, the explanation and solution is simple. If you leave the car in road height the computor will remain on and drain your battery. But also the car will constantly try to keep the air suspension level. The end result being that the compressor runs out of air to do this and it will sag somewhere. Hence when you restart it the compressor produces air and it all works again.
Solution - lock it in acccess mode when you park up, unless you are only going to be away for a short period. Benefits are that you will if nothing else not end up with a flat battery. TDV6 - gone
TDV8 - gone
Post #210716 Tue Feb 10 2009 10:16am
Yep ST is right mine did the same thing the LR calibrate it all fine after RRS TDV6 Gone but still around
Post #210799 Tue Feb 10 2009 11:51pm
Tim in Scotland
Josh, no need to lock it in access, just lowering it to access is enough. Mine gets left for 3 months at a time and often in normal mode (my father has not sussed out the lowering to access height even after 6 years of driving my FFRR and both RRS's and he claims to have read the entire owners manual!) and I have never come home to a flat battery - it does sink on it's suspension to access level over about a week though!
The one time the last RRS got left locked in access height by father, he didn't realise what he had done and called out LRA because the car wouldn't go above 30mph without sounding the gongs - he was very worried he had damaged the car or that it had a serious fault! That's difference between pressing the button for long enough to activate the lowering and hitting it with a hammer blow and then holding it down for more than 5 seconds like so many oldies do. My father is the only home computer user I know who wears out keyboards because he hits the keys so hard! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #210833 Wed Feb 11 2009 10:30am
rrsboy
i cant believe that when parked, the air suspension computer is still on/trying to level the suspension/draining the battery. are you sure that is correct?
Post #210966 Wed Feb 11 2009 7:15pm
Roland
Switzerland
My car even lowers to below access height after a week or so and it doesn't matter whether I park it in normal or in access height. It looks as if there's no air left at all in the suspension bags. Crying or Very sad SOMETIMES YOU'RE THE BUG AND SOMETIMES YOU'RE THE WINDSHIELD
2010 TDV8 Ultimate Edition, zermatt-ebony-grand lacquer, and all the goodies, plus Superchips Bluefin ECU performance upgrade, Gibson Performance exhaust tips
gone after only 7 months: MY10 TDV63.0 HSE, zermatt-ebony-anigree, Dynamic Response, Rear diff-lock, flappy paddles, premium leather, Sunroof, PTI, privacy glass, S/C design 5 Spoke Diamond Turned alloys
Post #211189 Thu Feb 12 2009 1:10pm
Tim in Scotland
No it isn't correct............................... or if it is then the batteries must be dammed good as I leave mine car unmoved for three months at a time and it always starts first turn of the key, even at this time of the year when we get down to -10c on occassion, and the car is not garaged. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #211224 Thu Feb 12 2009 2:46pm
umbertob
United States 2006 Range Rover Sport 4.4 V8 HSE Chawton White
The shop manual states that the suspensions module "wakes up" 2 hours after turning off the ignition, and every 6 hours after that, automatically when the car is parked. It checks vehicle height and, if the car is not level within a specific tolerance, it makes small downward adjustments then goes back to sleep for 6 more hours... So it's definitely possible that the car may slowly lower to a height lower than what you left her in over extended time. But since your car leans quite noticeably after a couple of days, I believe your system may have developed a very small leak in an exhaust valve (or an air spring), causing it to slowly sag on one side. The module compensates for this by lowering the car a little bit every 6 hours to level it, and if this goes on long enough the suspensions could go down all the way to the bump stops, in theory.
Post #211239 Thu Feb 12 2009 3:20pm
rrsboy
thanks umbertob, that sounds logical enough. i'll get it checked by a stealer.
Post #211316 Thu Feb 12 2009 7:25pm
Markos
Slovenia 2008 Range Rover Sport TDV8 HSE Java Black
rrsboy did you already solved the problem? It seems that my car has exactly the same problem as yours Crying or Very sad just that I did not notice it until recently because I always park my car in access mode in my garage and than you can not see it. But now I parked it out side of the garage a few times and I noticed that after approx.2h car leans on left back side like yours. Please let me know if your stealer already found a fix for it. 2008 RRS TDV8 HSE, Java black, Alpaca,.....
Post #211693 Sat Feb 14 2009 11:11pm
