Home > Off Roading & Green Laning > Sticking to first gear |
Welocme to the forums.
Sun Feb 01 2009 4:28pm |
teMoony Member Since: 01 Feb 2009 Location: Dubai Posts: 5 |
DSC is switched off and I'm using sand mode.
Sun Feb 01 2009 4:43pm |
dazsear Member Since: 23 Nov 2008 Location: Lincolnshire Posts: 851 |
Here is the exact dune I'm trying to climb
Sun Feb 01 2009 5:25pm |
PJPR01 Member Since: 12 Mar 2006 Location: Houston, Texas Posts: 355 |
If you truly want to stay in 1st only, then you have to shift the car into Sport mode, then manually downshift to 1, it will stay there. Suggest trying it on a flat surface first so you get the hang of it, and then charge up the dune.
Mon Feb 02 2009 12:29am |
Shifting the car to sport mode and then manually downshifting to first will not force the car to stay in first gear....
Mon Feb 02 2009 8:11am |
Well then Mr. TeMoony...I suggest you buy another vehicle, or keep the RPM's to 5990 or accept the fact that you won't make it up the hill with your current driving technique. PJPR
Mon Feb 02 2009 6:05pm |
dadanek Member Since: 30 Mar 2008 Location: Heart of Europe Posts: 450 |
Moony, and what about to try ONLY second gear? from beginning till the end of the dune RANGE ROVER, MORE THAN A CAR, LESS THAN A KITKAT |
Mon Feb 02 2009 7:16pm |
umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944 |
Can't do it. Even in CommandShift mode, there are "safety" shift point maps used by the ZF tranny, which will either upshift at high revs (you mention 6K RPM, I'll buy it... Never really tried to push any gear that high in manual) to protect the engine from overspeed damage, or will downshift to avoid the engine from stalling if you are in the opposite situation. |
Mon Feb 02 2009 11:47pm |
PJPR01... what "Current driving technique"?
Tue Feb 03 2009 11:53am |
Your own answer just provided a clue to the "driving technique".
Tue Feb 03 2009 5:20pm |
I intend to ask them this friday |
Tue Feb 03 2009 6:15pm |
