Home > Off Roading & Green Laning > Sticking to first gear
teMoony
United Arab Emirates 2006 Range Rover Sport Supercharged Chawton White
Yo!
My question is: Is there a way to force the car to use first gear only and not change to second even if I rev it all the way?
I live in the UAE, and here we have HUGE sand dunes... the problem is that when I put the car in first gear and attempt to climb one... the car changes to second gear at around 6000rpm half way from the top which causes the car to sink in immediately.
I used to have the same problem with my Hummer h3 but found out that if I don't use the 4x4 high gears, the car just revs all the way and sticks to its gear.
Oh yeah.. its a 2006 Range rover sport supercharged.
Post #209463 Sun Feb 01 2009 4:58pm
Tim in Scotland
Welocme to the forums.
I assume that you also have the DSC switched off and the sand mode selected on the TR? Also are you in low box? If you don't have the DSC off then try again with it inhibited it will make a big difference.
Why are you using 1st and not a higher gear, like 2nd or 3rd low and utilising the torque of the engine?
I'm not experienced in driving offroad in sand - we have loads of mud and water here!
There are other members here in the Emirates - I know Sportman in Dubai takes his Supercharged off into the sand and has never complained of problems 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #209465 Sun Feb 01 2009 5:28pm
teMoony
DSC is switched off and I'm using sand mode.
First gear is the best gear when trying to climb sand dunes, second is also good if you have space... using 3rd+ is impossible because you lose your revs immediately which kinda sucks.
Also, you need momentum to climb sand dunes, and the act of changing gears mid climb means that you lose most of your speed and momentum which sinks the car in the sand right away.
Here is the exact dune I'm trying to climb
Also, in this video you can hear the cars using first gear only.
Yes... its a bumpy ride lmao.
*Edit*
A better angle &feature=related
Post #209466 Sun Feb 01 2009 5:43pm
dazsear
There are some rather 'interesting' other videos from the person who added the film..... kind of makes me wary of Utube for the very exact reasons...... perhaps its just me!
The dune looks good though!
Daz 2017 4.4 Autobiography FFRR - love this car
Gone - VW T5 Transporter
Long gone - 2009 Disco
Long gone but never out of my thoughts - 2008 TDV8 HST
Post #209475 Sun Feb 01 2009 6:25pm
PJPR01
United States 2006 Range Rover Sport 4.4 V8 HSE Cairns Blue
If you truly want to stay in 1st only, then you have to shift the car into Sport mode, then manually downshift to 1, it will stay there. Suggest trying it on a flat surface first so you get the hang of it, and then charge up the dune.
Also...I presume that you have aired down your tires appropriately to "float" on the sand or you will dig in.
Sand Mode, DSC off all good...almost there.
Send a video once you make it up the hill...
Very Happy PJPR
Cairns Blue HSE
180k Miles of Adventure
Post #209530 Mon Feb 02 2009 1:29am
teMoony
Shifting the car to sport mode and then manually downshifting to first will not force the car to stay in first gear....
As soon as you reach 6000rpm the car automatically shifts to second gear.
I'm not sure if its clear in the vids or not, but the hill is around 45 degrees up hill. Even if the tires are at 10psi, you still need speed to climb that hill.
Post #209553 Mon Feb 02 2009 9:11am
PJPR01
Well then Mr. TeMoony...I suggest you buy another vehicle, or keep the RPM's to 5990 or accept the fact that you won't make it up the hill with your current driving technique. PJPR
Cairns Blue HSE
Post #209689 Mon Feb 02 2009 7:05pm
dadanek
Czech Republic 2007 Range Rover Sport Supercharged Java Black
Moony, and what about to try ONLY second gear? from beginning till the end of the dune Cool RANGE ROVER, MORE THAN A CAR, LESS THAN A KITKAT
Post #209696 Mon Feb 02 2009 8:16pm
umbertob
United States 2006 Range Rover Sport 4.4 V8 HSE Chawton White
Can't do it. Even in CommandShift mode, there are "safety" shift point maps used by the ZF tranny, which will either upshift at high revs (you mention 6K RPM, I'll buy it... Never really tried to push any gear that high in manual) to protect the engine from overspeed damage, or will downshift to avoid the engine from stalling if you are in the opposite situation.
Post #209718 Tue Feb 03 2009 12:47am
teMoony
PJPR01... what "Current driving technique"?
Anyway... is it possible to disable that safety function? Because I've seen a couple RRS's climb that hill. I even saw one climb it in reverse. But i think that one had extra power anyway.
Could probably climb it in 2nd gear, but that would probably destroy the car because of all the bumps on the way up.
Post #209746 Tue Feb 03 2009 12:53pm
PJPR01
Your own answer just provided a clue to the "driving technique".
If other RRS's are making it up the hill, why not ask them how they did it? PJPR
Cairns Blue HSE
Post #209799 Tue Feb 03 2009 6:20pm
teMoony
I intend to ask them this friday
Post #209802 Tue Feb 03 2009 7:15pm
