![]() | Home > Off Roading & Green Laning > Sticking to first gear |
Welocme to the forums.
teMoony Member Since: 01 Feb 2009 Location: Dubai Posts: 5 ![]() ![]() ![]() |
DSC is switched off and I'm using sand mode.
dazsear Member Since: 23 Nov 2008 Location: Lincolnshire Posts: 851 ![]() ![]() |
Here is the exact dune I'm trying to climb
PJPR01 Member Since: 12 Mar 2006 Location: Houston, Texas Posts: 355 ![]() ![]() ![]() |
If you truly want to stay in 1st only, then you have to shift the car into Sport mode, then manually downshift to 1, it will stay there. Suggest trying it on a flat surface first so you get the hang of it, and then charge up the dune.
Shifting the car to sport mode and then manually downshifting to first will not force the car to stay in first gear....
Well then Mr. TeMoony...I suggest you buy another vehicle, or keep the RPM's to 5990 or accept the fact that you won't make it up the hill with your current driving technique. PJPR
dadanek Member Since: 30 Mar 2008 Location: Heart of Europe Posts: 450 ![]() ![]() ![]() |
Moony, and what about to try ONLY second gear? from beginning till the end of the dune |
umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944 ![]() ![]() ![]() |
Can't do it. Even in CommandShift mode, there are "safety" shift point maps used by the ZF tranny, which will either upshift at high revs (you mention 6K RPM, I'll buy it... Never really tried to push any gear that high in manual) to protect the engine from overspeed damage, or will downshift to avoid the engine from stalling if you are in the opposite situation. |
PJPR01... what "Current driving technique"?
Your own answer just provided a clue to the "driving technique".
I intend to ask them this friday |
