![]() | Home > General > cig lighter not working - easy fix? |
Wozz Member Since: 28 Dec 2008 Location: Cheshire, United Kingdom Posts: 826 ![]() |
I highly recommend quitting smoking as a quick fix. Failing that I am of no more use sorry |
could be a number of things so best get the dealer to fix. Remember the socket only works when ignition is on. 2005 Zambezi TDV6 - Gone but not forgotten
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 ![]() ![]() ![]() |
Fuse |
georgio Member Since: 07 Apr 2008 Location: Nicosia Posts: 21 ![]() ![]() ![]() |
I had the same problem 2 weeks ago, but after took it at the dealer to fix it i realise that the socket now works when the ignition is off, the engine off, even when the car is completeley locked... Is that right? Before taking it to the dealer, it wasnt like that as i remember always had the phone charger connected to that socket... Can anyone advise me what to do... RRS TDV8 HSE Java Black |
umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944 ![]() ![]() ![]() |
Uh, get a bigger battery and count your blessings? ![]() ![]() |
ANd what umbertob is saying there is no it isn't right - nothing has power with the keys out - only the radio unit and then only for 20 or 30 mins or so before self terminating. |
TB Member Since: 19 Feb 2006 Location: Depends who wants to know . . . Posts: 5927 ![]() ![]() ![]() |
Sounds like someone at the dealership has co |
Yeah that don't sound right
2nd Rower Member Since: 12 Nov 2007 Location: Upside Down Posts: 1382 ![]() ![]() ![]() |
As I now understand the front cig lighter is on a different circuit to the rear and boot sockets. Last edited by 2nd Rower on Sun Jan 11 2009 9:51pm. Edited 1 time in total |
Have just got back from the Aussie RRsport weekend meet, and one of the guys who is not a member on here has solved this - he has his Waeco fridge powered 24/7 in the boot of his TDV6 from the factory power socket in the boot. I have the instructions and will try and get it done on my asap and post some details and photos up as soon as I get chance..... |
tiny Member Since: 13 Jan 2009 Location: jindabyne Posts: 6 ![]() ![]() ![]() |
on 2007 tdv6 centre and rear power sockets are on a seperate relay and fuse to the front cigar lighter outlet. Rear and centre outlets can be set up to be non switched from ignition by removing relay r203 from behind glove box and putting a wire bridge across the power terminals. 2.7 RRS TDV6, java black, Cruise, Sunroof, tow pack, Tasmod Sills, brembos, 20 inch rims, tinted windows, premium ice, adaptive bi xenons.
Nice one Tiny!! |
This is the offending relay that needs to be 'replaced' per Tiny's instructions above
A picture of the wire bridge would be very helpful.
