![]() | Home > General > cig lighter not working - easy fix? |
2nd Rower Member Since: 12 Nov 2007 Location: Upside Down Posts: 1382 ![]() ![]() ![]() |
The wire bridge is simply a short wire with correct sized connectors (same as relay being removed) crimped onto either end, that then goes from the top terminal to the bottom terminal after the relay is removed.
tiny Member Since: 13 Jan 2009 Location: jindabyne Posts: 6 ![]() ![]() ![]() |
Picture of bridge as requested, piece of wire with two spade terminals attached. also placed info in new post by 'very annoyed' in 'tips and tricks'. ![]() 2005 Porsche Boxster S for the fun asphalt days. Ducati Monster 696 termi racing pipes and computer and carbon fibre bits. |
Great - good work. 2005 Zambezi TDV6 - Gone but not forgotten
jack.bauer Member Since: 30 Sep 2012 Location: london Posts: 277 ![]() |
so this allows rear and centre sockets to provide power without keys in ignition? 07 TDV8 + BAS map |
