Home > General > TDV8 Problem????
klm
2008 Range Rover Sport TDV8 HSE Stornoway Grey
TDV8 Problem????
Have any of you guys experienced problems with starting your TDV8 as now and again when I go to start mine it sometimes just clicks and doesn't start, bit like a starter motor problem but when I turn the key off and on a few times it starts. Question
Post #168756 Tue May 06 2008 5:21pm
Alicatt
Belgium 2008 Range Rover Sport TDV8 HSE Buckingham Blue
The one I drove on the landrover experience had the same fault, the guy said it was a problem with some of the earlier ones, don't remember what the cure was (if) Sons of dogs come hither and get flesh
Clan Cameron
Post #168757 Tue May 06 2008 5:28pm
klm
Ummmmm interesting, mine is a 57 plate looks like a visit to the dealer for that plus the knocking from the front end but I know now what their response to the knocking will be, "It's down to the 22" wheels sir" Rolling Eyes
Post #168758 Tue May 06 2008 5:36pm
NickM
Klm, nothing to do with the thread - but you car looks gorgeous!!! Thumbs Up
Post #168760 Tue May 06 2008 5:54pm
kam100
I second that!
Post #168794 Tue May 06 2008 9:45pm
Tim in Scotland
KLM are you using only one key fob most of the timeand then occassionally picking up the other one which has a near flat battery due to lack of use? Remember the battery charges through the ignition slot, it isn't a changable battery like Land Rovers with the same fob used to have 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #168796 Tue May 06 2008 10:02pm
Texstar
It could be something as simple as a loose battery terminal connection,(dealers sometimes don't check these on a pdi Rolling Eyes ), or poor connections at the starter motor or solenoid, or negative battery cable to body (poor connection).......Let us know if they find the problem. RRS TDV8 Buck Blue (no, not now in my dreams). ..........D3 TDclankety clankV6 ............BMW 318i
Post #168799 Tue May 06 2008 10:39pm
Steve
Australia 2008 Range Rover Sport TDV8 HSE Java Black
I had my starter motor replaced as it would do the same thing. Sometime started first go and others it took 6 goes. According to LR in Brisbane it was a sticking solenoid. Hope ths helps you. Other than my TDV8 is runnng smooth as... Steve
Post #168801 Wed May 07 2008 1:45am
flydive
I had the same problem at the beginning with my TDV6, usually happened at the 2nd or 3rd start of the day. I believe I was too quick inserting then turning the key. Now I insert the key, wait a bit (sometimes wait for the "checking system"message to go out) then start, never had the problem again. '08 RRS TDV8
Post #168805 Wed May 07 2008 7:21am
klm
Thanks for the comments guys about the car, gave it a good valet today so I will post some pics later as it really does look good.
I'll get the dealer to take a look asap as it is doing it all the time now so thanks for letting me know what you've had replaced at what they should check first.
I'll keep you updated Thumbs Up
Post #168878 Wed May 07 2008 3:27pm
Jonathan
England 2012 Range Rover Sport SDV6 Autobiography Fuji White
TDV8 Starter motor
Hi
I appreciate this is an old post however I had the same problem so took it to the dealer and they fitted a new starter motor about 2 weeks ago. All fine until Saturday when it took 2 trys to start.
Did you get any resolution to the problem in the end or did it just go away. I am reluctant to take the car back to the dealer with the same problem as it's obviously not what they thought it was first time!!
Any help gratefully appreciated.
Jonathan Jaguar XKR Convertible
MY 2012 Range Rover Sport TDV6 Autobiography in Fujian White....Mmmmmmm
Range Rover Evoque 2.2 Prestige in white - gone
Porsche Boxster S White with lots of extras! Gone
Lotus Elise 2011 Touring for sunny days - gone!
Previously....
RRS TDV8 Black 57 Plate
645ci
Jag XKR Convertible (my wife still loves this car!)
BMW 530i
BMW 328i (I loved this car)
Golf R32
Post #198025 Mon Dec 01 2008 12:01pm
Jonathan - in this colder weather you must make sure your glow plugs are ready before turning the engine. When the glowplug light goes off in the display the plugs are ready. 2005 Zambezi TDV6 - Gone but not forgotten
Post #198026 Mon Dec 01 2008 12:04pm
Thumbs Up old school Diesel driving in winter Laughing
Post #198030 Mon Dec 01 2008 1:01pm
Jonathan
It also happens when the engine is warm guys? I will check what you are suggesting though and see if it works!
Cheers Jaguar XKR Convertible
Previously....
645ci
BMW 530i
Golf R32
Post #198077 Mon Dec 01 2008 4:41pm
klm
They just fitted a new starter motor and it has been ok since
Post #198229 Tue Dec 02 2008 8:47pm
