![]() | Home > Maintenance & Modifications > When changing my 19s to 20s on Friday ......... |
C10CKO Member Since: 19 Sep 2007 Location: Amazingstoke Posts: 100 ![]() ![]() ![]() |
When changing my alloys from 19s to 20s on Friday, at the tyre shop, do I have to be carefully about them jacking up my beloved RRS? A mate says if not jacked up properly, in the correct suspension setting, it could screw the suspension 'cos its 'self leveling'! Is that correct or complete BS?? What needs to be done if anything?
TB Member Since: 19 Feb 2006 Location: Depends who wants to know . . . Posts: 5927 ![]() ![]() ![]() |
It doesn't really matter. If you are using a reputable wheel & tyre centre they will use a large trolley jack or even a vehicle lift whilst changing your wheels.
Josh Member Since: 24 Dec 2005 Location: Here, there and everywhere Posts: 2054 ![]() ![]() |
From experience the only way they can jack it up is for you to lock it down in access mode as previously posted. Any other setting and the wheels won't leave the ground.
for wheel changing...
Markos Member Since: 09 Dec 2007 Location: Ljubljana Posts: 187 ![]() ![]() ![]() |
Bobby knows everything |
PJPR01 Member Since: 12 Mar 2006 Location: Houston, Texas Posts: 355 ![]() ![]() ![]() |
HHmm...actually the exact opposite of this is recommended in the manual. Raise the vehicle to off road mode and then jack up, not on the wheel suspension, but on the frame only. Also helpful to open the rear gate or a door once raised up to prevent relevelling. PJPR Cairns Blue HSE 180k Miles of Adventure |
Supertrotter Member Since: 10 Mar 2006 Location: Brrrr.... guess where :o( Posts: 9905 ![]() ![]() |
PJPR01 is spot on, you are supposed to put the RRS in off road height before jacking.
JPR Member Since: 07 Aug 2006 Location: Cleveland Posts: 289 ![]() ![]() |
and also pat your head while hopping on one leg |
am I missing something? ![]() 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
Thanks Guys. I will put my RRS into the off road height.
bellautos Member Since: 16 Feb 2006 Location: York, NorthYorkshire Posts: 496 ![]() ![]() ![]() |
Ask your local LR dealer to change the tyre size setting with the dealer tool also.
Rupert Member Since: 13 Mar 2006 Location: Here !!! Posts: 1194 ![]() ![]() |
Oh… that’s interesting !
Im 99% that that tyre size is in the diagnostic menu yes,if i get my car logged on to IDS again ill take a screen shot of the sizes available for change.
this is very interesting.. ![]() 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
