Home > Maintenance & Modifications > When changing my 19s to 20s on Friday .........
C10CKO
When changing my alloys from 19s to 20s on Friday, at the tyre shop, do I have to be carefully about them jacking up my beloved RRS? A mate says if not jacked up properly, in the correct suspension setting, it could screw the suspension 'cos its 'self leveling'! Is that correct or complete BS?? What needs to be done if anything?
Thanks guys,
C10CKO MY12 RRSport 3.0 SDV6 Autobiography
Orkney | Everything | Dynamic Pack | Park Heating | Cold Climate Pack | Privacy Glass | Extended Leather | 20inch alloys
Post #195887 Wed Nov 12 2008 9:46pm
paulL
Spain 2013 Range Rover Sport SDV6 Autobiography Fuji White
Locked down in access (hold down button until you get the padlock illuminated) is the way to go. 2013 RRS SDV6 Autobiography Fuji White
2007 RRS TDV8 HSE - gone -
2005 RRS TDV6 HSE - gone -
Post #195889 Wed Nov 12 2008 10:08pm
TB
United Kingdom 2006 Range Rover Sport TDV6 SE Arctic Frost
It doesn't really matter. If you are using a reputable wheel & tyre centre they will use a large trolley jack or even a vehicle lift whilst changing your wheels.
If you are really worried check out the jacking instructions in the boot. Do what ever it says on the information leaflet, you can't go wrong. Arctic Frost TDV6 SE. Aspen Leather, Cherry Wood, Privacy Glass, PTI, Tow Pack, Mudflaps, Tasmods, a new Fuelflap, a RRSport.co.uk umbrella in the boot & a RRSport.co.uk sticker on the rear glass.
__________________
Some people accuse me of thinking the world revolves around me, but I'm not stupid . . . I know it revolves around the sun. Which shines out of my @rse!!!
Post #195890 Wed Nov 12 2008 10:46pm
Josh
From experience the only way they can jack it up is for you to lock it down in access mode as previously posted. Any other setting and the wheels won't leave the ground.
You don't need to worry about anything else your mate told you.
Also make sure they torque the wheels by hand and don't use their airgun socket set to undo or tighten the nuts cos it might damage your alloys. TDV6 - gone
TDV8 - gone
Post #195891 Wed Nov 12 2008 11:09pm
Bobby
for wheel changing...
http://www.rrsport.co.uk/gallery/albums/userpics/10024/Jack.pdf
and general information on jacking the car...
http://www.rrsport.co.uk/gallery/albums/us...ifting.pdf Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #195894 Thu Nov 13 2008 12:41am
Markos
Slovenia 2008 Range Rover Sport TDV8 HSE Java Black
Bobby knows everything Very Happy 2008 RRS TDV8 HSE, Java black, Alpaca,.....
Post #195896 Thu Nov 13 2008 12:54am
PJPR01
United States 2006 Range Rover Sport 4.4 V8 HSE Cairns Blue
HHmm...actually the exact opposite of this is recommended in the manual. Raise the vehicle to off road mode and then jack up, not on the wheel suspension, but on the frame only. Also helpful to open the rear gate or a door once raised up to prevent relevelling. PJPR
Cairns Blue HSE
180k Miles of Adventure
Post #195900 Thu Nov 13 2008 4:16am
PJPR01 is spot on, you are supposed to put the RRS in off road height before jacking.
I did when I changed our 19's to 20's many moons ago, and also when we had 2 punctures.
Suspension is fine after doing so. Runner up - 2009 Best Avatar Award Sad
Post #195902 Thu Nov 13 2008 7:06am
JPR
and also pat your head while hopping on one leg Yawn Current
McLAren 720s
2019 G63 AMG
2018 Bentayga
Previous
2019 AMG GTR
2018 Urban SVR
2018 Urban FFRR
2018 AMG E63s Edition1
2018 SVR Rejected from Stratstone Teesside !
2017 G63 AMG 463 Edition
2017 M3 CP
2017 C63s AMG Edition 1 Motorsport
2016 RRS SVR
2016 Bentley GT Speed 626
2015 Audi RS6
2015 FFRR
2014 Bentley GTC V8
2014 Audi RS7
2011 Lumma CLR GT558
2014 BMW M3 F80
2010 BMW X5
2006 FFRR SC
2005 RRS HSE
Post #195915 Thu Nov 13 2008 10:11am
Bobby
am I missing something? Confused Malaysia Boleh!
Post #195927 Thu Nov 13 2008 10:56am
C10CKO
Thanks Guys. I will put my RRS into the off road height.
I will say though, that the LD dealer I bought her from told me today to do nothing and all will be fine...
Thanks,
Post #196061 Thu Nov 13 2008 9:04pm
bellautos
United Kingdom 2005 Range Rover Sport TDV6 HSE Cairns Blue
Ask your local LR dealer to change the tyre size setting with the dealer tool also.
Regards Pete
Post #196087 Fri Nov 14 2008 12:57am
Rupert
Ireland
Oh… that’s interesting !
Can you “Tell the Sport” that it has, for instance 255/55 19’s on rather than 255/50’s & then get correct speedo readings ??
The one thing stopping me putting on MTR’s is the speedo readings would be out of whack. Given that the D3 takes 55 19’s as standard I often wondered if the sport could be calibrated to do the same.
Post #196118 Fri Nov 14 2008 10:39am
bellautos
Im 99% that that tyre size is in the diagnostic menu yes,if i get my car logged on to IDS again ill take a screen shot of the sizes available for change.
Regards Pete
Post #196132 Fri Nov 14 2008 11:27am
Bobby
Regards Pete
this is very interesting.. Surprised Malaysia Boleh!
Post #196136 Fri Nov 14 2008 11:39am
