Home > General > Tyre Size |
donnahcbc Member Since: 10 Oct 2008 Location: Geneva Posts: 8 |
Can I fit 255/55/19 sized tires to my RR Sport? Normal size is 255/50/19 |
Fri Oct 10 2008 10:12am |
Yes you can, but I'm not sure there was ever much choice out there....
Fri Oct 10 2008 10:33am |
What's FFRR?
Fri Oct 10 2008 11:29am |
Supertrotter Member Since: 10 Mar 2006 Location: Brrrr.... guess where :o( Posts: 9905 |
Full Fat Range Rover.
Fri Oct 10 2008 11:39am |
Oh, Ok thanks for clearing up my confusion |
Fri Oct 10 2008 12:12pm |
Can I use the same alloys? |
Fri Oct 10 2008 12:19pm |
You certainly can
Fri Oct 10 2008 12:20pm |
OH goody, so pleased now. Why do land Rover put 255/50's on then? |
Fri Oct 10 2008 12:22pm |
simonsi Member Since: 01 Dec 2006 Location: Leicester Posts: 259 |
255/55/19 is the D3 std 19" size. LR clearly want the RRS to be a more sporty ride in all senses so dropping the aspect ratio gives slightly better acceleration, firmer ride, arguably better looks
Fri Oct 10 2008 12:48pm |
Ok, by my reckoning from all the answers on here it will make little difference to me as we are in the mountains and go off road every day just to get home. |
Fri Oct 10 2008 12:58pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 184 |
your better off with the 55 tyres then as you will have more ground clearance - by a few mm |
Fri Oct 10 2008 2:06pm |
Yep - also good to see an RRS being used for "real"
Fri Oct 10 2008 2:25pm |
We had a Disco 2, which was great, but off road in comparison to the RR sport is not in the same league. Lower gearing on the sport gives greater control, especially on icy descents and for rocky terrain. Unfortunatly it does eat tyres and that gets a bit expensive. |
Fri Oct 10 2008 3:41pm |
Roland Member Since: 10 Jun 2005 Location: NB Posts: 469 |
If you are interested I could sell you four 255/50 R19 Vredestein Wintrac 4 xtreme for say CHF 500.00 the set. There is very little difference between 50 and 55 size and it should be cheaper for you to return the ones you've ordered and get mine...? They are great tyres and have about 8'000 km on them and still look like new. Let me know if you are interested. I am based near Lake Constance and shipping them to your area should be cheap enough. SOMETIMES YOU'RE THE BUG AND SOMETIMES YOU'RE THE WINDSHIELD 2010 TDV8 Ultimate Edition, zermatt-ebony-grand lacquer, and all the goodies, plus Superchips Bluefin ECU performance upgrade, Gibson Performance exhaust tips gone after only 7 months: MY10 TDV63.0 HSE, zermatt-ebony-anigree, Dynamic Response, Rear diff-lock, flappy paddles, premium leather, Sunroof, PTI, privacy glass, S/C design 5 Spoke Diamond Turned alloys |
Sat Oct 11 2008 6:00am |
