Home > General > Tyre Size
donnahcbc
Switzerland 2005 Range Rover Sport TDV6 HSE Rimini Red
Tyre Size
Can I fit 255/55/19 sized tires to my RR Sport? Normal size is 255/50/19 Confused
Post #191536 Fri Oct 10 2008 10:12am
Yes you can, but I'm not sure there was ever much choice out there.... Confused
Post #191537 Fri Oct 10 2008 10:33am
Vogue
Thats the same size as on a FFRR with 19", diameter is larger, ride will be better, less likely to damage your rims, but the gearing will also be slightly higher so your acceleration will be down slightly, but top speed will be slightly up.
Bit of useless info :- The 50 profile 19" tyres that are already on your vehicle are the same profile as OEM FFRR 20"
Post #191541 Fri Oct 10 2008 10:50am
donnahcbc
What's FFRR?
I ordered the new winter tyres yesterday and stupidly clicked on the wrong size Embarassed . If I can fit them it would be great as they have already been despatched and to send them back would be at my expense. They are also cheaper than the 255/50/19's
Post #191547 Fri Oct 10 2008 11:29am
Full Fat Range Rover.
The big one as opposed to the smaller Sport Thumbs Up Runner up - 2009 Best Avatar Award Sad
Post #191551 Fri Oct 10 2008 11:39am
donnahcbc
Oh, Ok thanks for clearing up my confusion
Post #191563 Fri Oct 10 2008 12:12pm
donnahcbc
Can I use the same alloys?
Post #191567 Fri Oct 10 2008 12:19pm
You certainly can Thumbs Up
Post #191569 Fri Oct 10 2008 12:20pm
donnahcbc
OH goody, so pleased now. Why do land Rover put 255/50's on then?
Post #191570 Fri Oct 10 2008 12:22pm
simonsi
United Kingdom 2007 Range Rover Sport TDV6 HSE Arctic Frost
255/55/19 is the D3 std 19" size. LR clearly want the RRS to be a more sporty ride in all senses so dropping the aspect ratio gives slightly better acceleration, firmer ride, arguably better looks
Putting 255/50 on a D3 definitely looks too small, haven't ever seen 255/55 on an RRS.... Cheers
Simon
2007 2.7HSE 20" Wheels
2005 TDV6 D3 S Auto - Zambezi Silver - JE Tune - RRS 19" - Sidesteps - Roof Rails
Body Side Strips - Xenons - Bright Pack - Cold Pack - Premium Stereo
Alpine Roof - Towpack - Alpine Touchscreen Satnav - Veba Rear DVD changer
Alpine Roof Monitor - Webasto FBH Timer - Brembo Frt & S/C Rr Brakes
Post #191573 Fri Oct 10 2008 12:48pm
donnahcbc
Ok, by my reckoning from all the answers on here it will make little difference to me as we are in the mountains and go off road every day just to get home.
Post #191575 Fri Oct 10 2008 12:58pm
Vogue
your better off with the 55 tyres then as you will have more ground clearance - by a few mm Cool
Post #191577 Fri Oct 10 2008 2:06pm
Yep - also good to see an RRS being used for "real" Wink Thumbs Up
Post #191582 Fri Oct 10 2008 2:25pm
donnahcbc
We had a Disco 2, which was great, but off road in comparison to the RR sport is not in the same league. Lower gearing on the sport gives greater control, especially on icy descents and for rocky terrain. Unfortunatly it does eat tyres Big Cry and that gets a bit expensive.
Post #191590 Fri Oct 10 2008 3:41pm
Roland
Switzerland
donnahcbc wrote:
What's FFRR?
If you are interested I could sell you four 255/50 R19 Vredestein Wintrac 4 xtreme for say CHF 500.00 the set. There is very little difference between 50 and 55 size and it should be cheaper for you to return the ones you've ordered and get mine...?
They are great tyres and have about 8'000 km on them and still look like new. Let me know if you are interested. I am based near Lake Constance and shipping them to your area should be cheap enough. SOMETIMES YOU'RE THE BUG AND SOMETIMES YOU'RE THE WINDSHIELD
2010 TDV8 Ultimate Edition, zermatt-ebony-grand lacquer, and all the goodies, plus Superchips Bluefin ECU performance upgrade, Gibson Performance exhaust tips
gone after only 7 months: MY10 TDV63.0 HSE, zermatt-ebony-anigree, Dynamic Response, Rear diff-lock, flappy paddles, premium leather, Sunroof, PTI, privacy glass, S/C design 5 Spoke Diamond Turned alloys
Post #191626 Sat Oct 11 2008 6:00am
